Thread: Binding Issues
Old 04-30-2008, 11:13 PM   #1
Default Binding Issues
I have a DX3 and an SR3500 I'm trying to bind. I have had the combo together for about a month and a half now and all of a sudden it just started flashing after taking it out of one truck and putting in back into another truck and it hasnt worked since. I tried to bind it but its not binding. I tried to rebind my SR3001 and it will bind fine, whats up with my SR3500?
Trimmy is offline   Reply With Quote
Old 05-01-2008, 12:15 AM   #2
are you removing the bind plug?
Is the bind plug in the BATTERY/BIND slot?
did you try calling horizon hobby tech?
mysharona is offline   Reply With Quote
Old 05-01-2008, 12:32 AM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Did you install a CC BEC?
JohnRobHolmes is online now   Reply With Quote
Old 05-01-2008, 08:11 AM   #4
Ya I installed a CC BEC and I have the bind plug in the B port and the bec plugged into the channel three. I even pulled it out of the truck totally and tried to bind it with a 6v recevier pack and it still wouldn't bind.
Old 05-01-2008, 09:13 PM   #5
I called horizon hobby only for them to tell me they were busy and they would call me back, soooo four hours later I get a call when I was 30 minutes away from home so horizon didn't help :-(
Old 05-03-2008, 05:35 PM   #6
Anyone have any idea????
Old 05-03-2008, 06:30 PM   #7
when you installed the bec did you install it into the throttle channel and the bind plug in the battery/bind channel?
Dickie691986 is offline   Reply With Quote
