Thread: HH Scorpion HK-2221-12
Old 05-01-2008, 08:51 AM   #1
Default HH Scorpion HK-2221-12
I need to knock some diameter off my motor due to my new setup and I like the kv and size of this motor.
Currently a 35t Integy w/ 8t pinion. 2100mah 3S LiPo. Sidewinder w/ BEC
I wanted to know if anyone has personally used it(Scorpion). Hows the startup and control of this motor? 12 poles right? I was thinking a 7 or 8 tooth pinion would help out either way. The required motor plate is only .080" correct?
Any input is appreciated.
BigRocks is offline   Reply With Quote
