| | #1 |
| Quarry Creeper Join Date: Jan 2008 Location: fair oaks nor-cal
| okay so heres what happened i was crawling at my creek but i was trying a line i never did before and my axial took a turn for the worst it slide and i tryed to give it power to go back up but ended up doing a back flip into the creek |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jan 2007 Location: US
| Dunno about warranty.... if you are not going that route...open it up, and let it air out. I've had several ESCs work fine after airing out... ofcouse, I also unplugged them ASAP. |
| | #3 |
| | #4 |
| Rock Crawler Join Date: Apr 2008 Location: Greentown
| ouch. is you steering servo OK? |
| | #5 |
| yea my sterring works but not the throttle :-( |
| | #6 |
| Pebble Pounder Join Date: Oct 2007 Location: Northern Virginia
| yea air it out for a day or so, I drowned my novak hv-maxx esc and it got soaked, stopped working then started but started all glitchy. after a couple of days airing out, works fine, no problems since. |
| | #7 |
| good news i got it open and the inside is as dry,as dry can be but i was going to go to radio shack and buy electonic board cleaner cause the out side wire leads are caked in with mud but i hope it works after words =] thank you to all that helped |
| | #8 |
| Rules? What Rules! ![]() Join Date: Apr 2008 Location: Tallahassee, Fl.
| It's not a good idea to clean the boards in the speedo with the cleaner as the boards have a coating on them that the cleaner can strip off & without the coating the components can & will arch to each other causing a short. The coating is called conformal coating. I do avionics repair & that is now we strip the coating from a board to replace a electronics part on a board. The best way is to let it air dry or use alcohol to clean any part of a speed control or receiver or any part of a electronic part. |
| | #9 | |
| Quarry Creeper Join Date: Jan 2006 Location: Orlando
That being said, I suggest removing the ESC from the vehicle and removing the case. Clean it using a bristled brush and alcohol. While it's apart, visually inspect it for any components or spots on the PWB that look dark from a possible burn. If you see any, I suggest sending it into Novak and paying for their flat rate repair on the ESC rather than risking more damage to it by attempting to run it again. | |
| | #10 |
| aw this suck i wanted to go to a comp on the 4th :-(:-(:-(:-( |
| | #11 |
| Quarry Creeper Join Date: Oct 2005 Location: ELLENSBURG, WA
| | #12 |
| | #13 |
| yes!!:-P its working again !!!!!!!! thank god i dont have to buy another one |
| Thread Tools | |
| Display Modes | |
