Thread: How many cells can I run on the Tazer ESC?
Old 05-29-2008, 09:04 AM   #1
Default How many cells can I run on the Tazer ESC?
http://www.dynamiterc.com/Products/D...=DYN4910#specs I am looking at getting this one this week used from a buddy (buying either way), I was just wondering if I could run more than 7 cells on this ESC without smoking it. The website says a max of 7, but I wonder if that is just a precautionary thing, and if I could actually run an 8 or 9 cell.
Thanks
dIma
Flatty is offline   Reply With Quote
Old 05-29-2008, 09:07 AM   #2
Thanks
dIma
No! it will smoke up even with 7 cells from my experience
rockwerks is offline   Reply With Quote
Old 05-29-2008, 09:11 AM   #3
It could work on more cells, but to how long would be the next question... They mark it safe for 7 cells because that's what the wireing and/or circutry can handle. And that's also going to be what's covered under any warrranty. You may or may not fry the ESC with more cells... So, is it worth it???
Cake Eater is offline   Reply With Quote
Old 05-29-2008, 09:45 AM   #4
So I would be best suited to just run a 7 cel pack and call it a day.
Dima
Old 05-29-2008, 06:27 PM   #5
dima, it took 3 runs to make it stop working with an 8 cell pack.
mike
yotee is offline   Reply With Quote
Old 05-29-2008, 09:33 PM   #6
Dima,
don't be greedy :P
7cells (8.4 volts) will give you mucho wheel-speed
If you want longer run-times, drop in a 55turn motor...
see you next Wednesday?
mr_manny is offline   Reply With Quote
Old 05-29-2008, 10:15 PM   #7
For only $30...............sure, why not
BJoe is offline   Reply With Quote
