Thread: Problems With Spectrum DX3R
Old 05-31-2008, 06:24 AM   #1
Default Problems With Spectrum DX3R
So I turned my Spectrum DX3R on this morning and everything works except for the 3rd channel that I'm using for dig. I pluged the dig servo into a different channel and it's fine, I turned on one of my other models and the 3rd channel works on it so what could be wrong?? I'm running a HS-5955TG on steering, HS-545BB, 5T Cobalt motor and a Mamba Max.
Tupers is offline   Reply With Quote
Old 05-31-2008, 07:11 AM   #2
Kamikaze's Avatar
You need to turn down your frame rate, Did it to me the first time.
Kamikaze is offline   Reply With Quote
Old 05-31-2008, 10:54 AM   #3
silly question, but did you assign any switches to activate your 3rd channel?
Also do as Kamikaze said, check your frame rates
mysharona is offline   Reply With Quote
Old 05-31-2008, 10:58 AM   #4
Thanks Kamikaze I set the frame rate to 11ms and it seems to been working fine now. Will having it set on 11ms be ok for the steering servo??
