| | #1 |
| Pebble Pounder Join Date: Mar 2008 Location: Plainfield
| I have a Tekin FX-R on my rig and I can't seem to get it into programming mode. The manual says to hold the mode button for 5 seconds then use the INC button to changes the values of the different features. When go to try o get into program mode, it blinks like it is going in but LED6 just stays lit and no other inputs will respond. It just sits there. I have to unplug the battery the plug it back in then it works like normal with all the factory settings. Another thing is the fact that the on off switch does not work. Once I plug the battery in, the ESC is on and working. I am using a CC BEC, does this have anything to do with that? Lou |
| Sponsored Links | |
| | #2 | |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| | #3 | |
| Fighting off whores ![]() Join Date: Jun 2004 Location: Whales
| | #4 |
| RCC Addict Join Date: May 2008 Location: Chicago/Bloomington
| Holding down the mode button any longer than 3 seconds will put you into radio configuration mode. To program it just give the mode button a tap and it goes into program mode then tap it the number of times it takes to go to the function you want to program in under 5 seconds or it returns to normal operation. For example: Tap it six times to go to the sixth LED to program the voltage cutoff, once you are there then tap the inc button to select the function like 1, 1&2 or 1,2&3 LEDs for the voltage cutoff example. Last edited by AreCee; 06-03-2008 at 08:10 AM. |
| | #5 |
| I have not really had a lot of time to get her sorted out. I will try today or tomorrow. I have busy with a new heli. I will let you know how it turns out. Lou |
| | #6 |
| Newbie Join Date: Feb 2008 Location: USA
| What AreCee says is correct to correctly get into the programming mode. Tap the mode button, tap it again X amount of times to traverse the LED to the function you wish to program, us the INC button to change the value. Did you pull the red wire out of the reciever harness coming from the speed control? It's not needed if you are running a EBEC. To do so you simply take that little 3wire connector coming out of the FX-r and with a modeling knife or needle gently pull up the center tab on the connector to pull out the redwire. Then just bend that wire back and tape it up so it won't make contact with anything...haha, I'm sure you coulda figured that part out but there it is in all its glory LOL |
| | #7 |
| Quarry Creeper Join Date: Aug 2006 Location: Baumholder
| i don't mean to steal your thread but i am having a problem with mine also, about two weeks ago my battery wire came undone and shorted out my battery so the truck would barely go anywhere so thinking it was my battery i purchased a new one well that one came in today. now i plugged in the new battery and the servo works but it sounds like the motor stalls and will not turn. i don't know if they speed control got messed up or not. thanks in advance. sorry for stealing your thread |
| | #8 |
| rckcrawler, No worries at all mate. Take care of your self there, I just got back from FOB Echo a little bit ago. I would suggest you start a new thread specific to your problem so you can get better help. I got it all sorted out as far as the programming goes. I would have never thought to pull the POS wire from the ESC to RX cable. Thanks. I love the drag brake on this thing sick! Lou |
| | #9 | |
| | #10 |
| no the only way to do that is order a new and that will take forever to get here. i might mess with it some more to see what is going on. thanks for the help |
| | #11 |
| I wanna be Dave Join Date: Jan 2006 Location: CA
| | #12 |
| i got it figured out it was the control the forward is messing up i guess i will have to get a new one |
| | #13 |
| Bummer on the esc....don't ya have a spare cheapo around until you get a new FXR? |
| | #14 |
| my bad i was not saying that i messed up the speed control the controller itself is messed up when i hold down the throttle it barely goes so i have to pull it then release it and pul it quickley again and it goes good. tahnks for the help. |
| | #15 |
| Uh....you mean the radio transmitter is bad? |
| Thread Tools | |
| Display Modes | |
