Thread: using the tq3 reciever
Old 05-31-2008, 09:12 PM   #1
Default using the tq3 reciever
ok so i want to use the tq3 radio system but I have a question will I have to have a battery to power the reciever or will I just plug the esc into the no. 1 channel on the reciever? and then my steering servos into the other two thanks.
iceman320 is offline   Reply With Quote
Old 05-31-2008, 09:51 PM   #2
ecs plugs into the ch 2 port, some of the tq3 rx's don't have a bec function so you may have to use a cc bec or reciever battery pack
sparky0068 is offline   Reply With Quote
Old 05-31-2008, 09:53 PM   #3
your ECS will have a BEC built in to it, so hook the ECS to ch. 2 and front steer to ch 1 and the rear to ch3. You can run a sepreat battery back for the rx and the servos, BUT you have to pull out the red wire form the radio plug on the ECS to do so, then you just plug the rx battery into the batt spot on the rx
thumbman is offline   Reply With Quote
Old 05-31-2008, 09:53 PM   #4
The esc will power it. I personally like the ccbec's but you can get by with just plugging the esc in the #2 slot and the servos in #1 and #3.
MCSCOTT is offline   Reply With Quote
Old 05-31-2008, 10:14 PM   #5
does it matter which esc I use?
Old 05-31-2008, 10:30 PM   #6
WOW! You may really want to ask a mod to move this over to the newbie forum.
All of this will depend on the ESC you use, or more importantly, the BEC rating of that ESC. And then it will depend on the servo(s) you are using. If you are only running a single servo (steering), then most ESCs out there with a BEC will handle the load. If you put in a super high torque steering servo, or another servo on Ch. 3, a high BEC ESC, or an external BEC will probably be needed.
The ESC will never plug into Ch.1. On the TQ3 RX, steering servo goes into 1, ESC goes into 2, and whatever Aux. you want to run goes into 3.
This would be the point where you would want to list the specific equipment you want to run, and the specifics of the electronics you want to run. Your posts so far are really too generic to answer correctly.
Robb is offline   Reply With Quote
Old 05-31-2008, 11:59 PM   #7
ok I will be running two steering servos. for the 4ws that I have setup. and that will be it for now. later on I might add a dig setup but i will cross that bridge when I come to it. so for now I will just have the 4ws. so what will I need to run the 4ws?
Old 06-01-2008, 12:03 AM   #8
Old 06-01-2008, 01:39 AM   #9
what is the make and model number of the servos and esc you are trying to use?what model number rx do you have?
thatguy is offline   Reply With Quote
Old 06-01-2008, 04:18 PM   #10
i will be using two 645mg servos and probably a sidewinder esc, and will have the traxxas tq3 radio system.
