| | #1 |
| Newbie Join Date: May 2008 Location: israel
| Hi guys I have just received my Rooster crawler ESC , I have got 3 diodes. My Clod crawler has 2 motors . My Q is : do i need to put this diodes also in the second motor ? if so i will need to buy another kit so this is important to me . Have anyone of you tried to operate the Clod with the diodes installed only on 1 motor ? Thank you guys , David |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| If the motors are 55T or higher, you probably won't even need any capacitors. If the motors are under 55T, I would install them on both motors. You can pick up four caps at Radio Shack for $3. |
| | #3 |
| MadDogRC LLC ![]() Join Date: Mar 2007 Location: Petaluma
| those are capacitors I don't run a clod but I'd say yes, you will need 3 per motor to avoid glithcing what motors will you use? sometimes they alread have a couple capacitors installed |
| | #4 |
| | #5 |
| Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
| the v10 has them built in. you dont need them. |
| Thread Tools | |
| Display Modes | |
