Thread: 2s or 3s lipo battery?
Old 06-01-2008, 07:32 PM   #1
Default 2s or 3s lipo battery?
ok... maybe this should be posted in the newbie section.. anyways, I am trying to finalize my electronic shopping list for two Trail scale trucks.
This battery is going to be used inside a Tamiya Hilux standard 540 motor temporarily until the new Trail truck kit from RC4WD is here. Then, the Hilux is going back to shelf. Everything except the motor are going to the new truck (haven't decide on the motor yet).
Should I buy a 2s lipo or 3s lipo?
sidewinder ESC
CC BEC
Hitec 5955 x(1)
Hitec 645 x(1) for shifting
Some LEDs
thx
psun786 is offline   Reply With Quote
Old 06-01-2008, 07:36 PM   #2
C U S T O M P A I N T
CrawlerGraphics's Avatar
3s and a HH Revolver Black...
Volt up - gear down...
CrawlerGraphics is offline   Reply With Quote
Old 06-01-2008, 07:43 PM   #3
3s always makes things more fun.
nigels_world is offline   Reply With Quote
Old 06-01-2008, 08:27 PM   #4
thx guys... but can a standard "stock" 540 motor (the one came with Tamiya hilux) handles 11.1v or 3s lipo?
Old 06-02-2008, 12:07 AM   #5
In between.
SACCO's Avatar
it can but is longevity could be shortened. I have been running an OLD silvercan with a 3s for 6 months with no issues in one of my scalers.
SACCO is offline   Reply With Quote
Old 06-02-2008, 01:26 AM   #6
thx... that settles it.
I am ordering a 3s 2000mAh from cheapbatterypack as we speak. :-P
Old 06-12-2008, 10:03 PM   #7
Trying not to post new threads, but what does the "s" stand for in 2s and 3s? Does this designate the number of cells?
gobucks is offline   Reply With Quote
Old 06-12-2008, 10:59 PM   #8
the number of cells or parallel circuts in a series. the s stand for series... I think
So as far as figuring voltage, yes.
Speedyboy is offline   Reply With Quote
Old 06-12-2008, 11:31 PM   #9
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
3s, and good choice on battery. You will want to keep the gearing pretty low and watch the trigger finger with stock motors, they can burst some hefty amps under throttle. What discharge rate did you select, 30C?
JohnRobHolmes is offline   Reply With Quote
Old 06-13-2008, 09:18 AM   #10
Is a 2s a good choice for a 55T and Castle Sidewinder w/ BEC and a casual crawler? Not many comps in my immediate area.
Old 06-13-2008, 10:15 AM   #11
Sure it will work just fine.
Old 06-13-2008, 06:40 PM   #12
Just a follow up; if eventually running brushless (i.e. crawlmaster) instead of the 55T, would the 3s be a better choice?
Old 06-13-2008, 07:03 PM   #13
2s would last longer but less power, 3s would have more power but it would not last as long so you have to find out if you want it to last or go fast
clod driver is offline   Reply With Quote
