| | #1 |
| Quarry Creeper ![]() Join Date: Dec 2007 Location: #
| the servo is getting extremly hot to the point where i cant even touch it for long at all. im running roster crawler esc tq3 radio set up futaba servo for dig hitec 5955 for steering this is on a 2.2 rig. steering moves freeley is there something im doing wrong or are they susposed to get that hot |
| Sponsored Links | |
| | #2 | |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
Typical $100 servo with a $25 radio problem. You need a better radio unless you can get the binding stopped with linkage. | |
| | #3 |
| Pebble Pounder Join Date: Mar 2008 Location: The state of 'Missery'
| If you are set on the TQ3,check out a servo strecher. http://www.servocity.com/html/180o_servo_stretcher.html |
| | #4 |
| i think its all good now moved it up a couple of holes on the servo horn and the only reason i use the tq3 is because i cant quite afford a better quality radio system someday i might have to |
| | #5 | |
| Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
| | #6 |
| Newbie Join Date: Feb 2008 Location: somewhere in ontario
| That'll work for now but in the future a radio with end point adjustment (EPA) will do the job. I have almost te same servo and using a futuba 3PM. It is a good radio versus its price. The servo gets mildly warm when it is crawling in the rocks. Is the futuba srevo at a normal temp? Last edited by xtremecrawler; 06-04-2008 at 05:35 AM. |
| | #7 |
| Rock Stacker Join Date: Dec 2007 Location: 45th Parallel
| Killa B, Does the TG 5955 have a metal band around it like the DS8711? If so, then check out my cross post for a Servo heat sink made from an old computer CPU heat sink. Servo Heat Sink for JR DS8711 Flynfrog |
| Thread Tools | |
| Display Modes | |
