06-07-2008, 02:34 PM | #1 |
Rock Stacker Join Date: Jul 2007 Location: Sweden
| 6-cell vs 8-cell
i have a BM9 Brushless Motor and a Mamba Max in my AX-10 should i go for a 6-cell battery pack or 8-cell battery pack. |
06-07-2008, 02:46 PM | #2 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
| cell count
I don't know about the motors limit, but w/ the MM I would go w/ a 8 or 10 cell sadle pack on the front axle.
06-07-2008, 02:52 PM | #3 |
Pebble Pounder Join Date: May 2008 Location: UK
I was wondering that quetions; why more than 6 cells; what advatage is there? The disadvantage is the weight I suppose.
06-07-2008, 03:13 PM | #4 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
Adds additonal voltage, which will increase wheelspeed when needed, provide better torque, and gives extra weight over the front tires when axle mounted for improved climbing.
06-07-2008, 03:28 PM | #5 |
Does it harm the motor putting more power though. I'll use the CC BEC and regulate it to 6v for servo's.
06-07-2008, 03:57 PM | #6 | |
No, more voltage is better and more efficient as long as you're not over the voltage limit of the equipment. After running 8 cells, I don't ever want to go back to less!!!!! I'm running Tekin FXR esc, 45t Integy motor, and Hi-tec HS945mg servo. | |
06-08-2008, 12:19 AM | #7 | |
Thanx | |
06-08-2008, 07:48 PM | #8 |
RCC Addict Join Date: Feb 2006 Location: ccxc
when you say 8cell are they 2/3?
06-08-2008, 07:56 PM | #9 |
yes, 2/3a cells. running 8 cells isn't going to hurt anything and the power and wheel speed is more than worth it!
06-09-2008, 07:17 AM | #10 |
great I'll put in an order for an bcell 2/3a saddle......i need more speed from the cobalt |
06-09-2008, 07:23 AM | #11 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I either run 8 cell 2/3 a packs, or 3 cell lipo packs.... I will never go back to 7.2 volts again |
06-09-2008, 07:27 AM | #12 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
Yeah, the first pack I installed on my new Axial is an 8-cell 2/3a saddle pack. I used cells from 2 Elite 1500 7.2V packs I thought were dead. Only one cell in each pack was actually dead and my 8-cell pack will take up to and even more than 1500mah when charging. Got over an hour and a half drive time last charge.
06-09-2008, 11:21 PM | #13 |
Rock Stacker Join Date: Mar 2008 Location: Dunedin(Tampa)
I have a tekin fxr and a 5645mg if I run the 8 cells do I have to run a bec?
06-09-2008, 11:38 PM | #14 |
