Thread: battery dies fast
Old 06-28-2008, 06:24 PM   #1
Default battery dies fast
so I got my crawler done I have a tq3 radio system and 4 wheel steer, and have noticed that the battery runs down pretty fast. Do I need to get a cc bec to connect to one of my servos? or will I have to run to tq3 receiver on a seprate battery? thanks.
iceman320 is offline   Reply With Quote
Old 06-28-2008, 07:10 PM   #2
What type and capacity of battery?
Mriswith is offline   Reply With Quote
Old 06-28-2008, 07:18 PM   #3
What kind of motor and servo information could help too...
FYI, when asking a question, the more info you give the better the answers.
Cake Eater is offline   Reply With Quote
Old 06-28-2008, 07:44 PM   #4
I have a 8 cell 1500mah split pack from tcs and the motor is a 65 turn integy, and I have two hitec 645 mg servos for the 4ws.?
Old 06-28-2008, 10:17 PM   #5
I am not going to lie, i think the pack is part of the problem,lol. I have been trying out those same cells, and not very happy with my run times just on a servo and motor. Your motor and 2 of the servos shouldnt create a big issue being I can run a 55T and a single 645 on a 1320 2 cell lipo for better part of an hour.
Mav-1981 is offline   Reply With Quote
Old 06-29-2008, 09:19 AM   #6
ok but does anybody have a split pack that's like 3000 mah? or is there some instructions somewhere that would show me how to build my own battery pack? cause I can't afford to switch to a lipo pack and charger right now.
Old 06-29-2008, 10:47 AM   #7
how fast is pretty fast? how much does the rig weigh? how's your gearing?
mysharona is offline   Reply With Quote
Old 06-29-2008, 10:59 AM   #8
i'm not sure how much my rig weighs. or how fast the battery dies I will have to time it when I go crawling next. but my gearing is a 21t pinion gear and a 87t spur gear. should I change my gearing?
Old 06-29-2008, 12:14 PM   #9
You could change your pinion to something like a 14 tooth. When I went from a 14 tooth to a 17 tooth I noticed my run time was reduced considerably.
All split packs will be about the same. That said, I get 45 min to an hour out of my 6 cell 1500's.
Harvo is offline   Reply With Quote
Old 06-29-2008, 12:35 PM   #10
ok guys I get about 15min out of my 8cell split pack if I change my pinion gear how much longer will I be able to run for? I will see how much it weighs later. Right now I'm thinking about buying a different chassis to put the drive train on.
Old 06-29-2008, 01:49 PM   #11
Sounds like you have a bad cell or pack. Did you break them in with a nice long slow charge? Those batteries shouldn't be charged at more than a 1 amp rate (or less if possible) for the first several charges.
Old 06-29-2008, 10:20 PM   #12
I charged it at 1.5 amps like tcs said. but I think your right about having a bad pack cause it charges for like five minutes and then the light on my charger starts blinking, so I think that I will have to buy another one and see what happens.
