Deciding on a ESC OK so I'm putting all the parts together for an axial ARR. But I still cant decide on the ESC. The one I am leaning to is the castle creations sidewinder. I am new to this forum and have read countless post talking about the benefits of the sidewinder. I just want a ESC that can handle what I want to do. I plan on installing a 4ws kit (I know i cant compete with 4ws) and I want an esp to handle it. My main questions are is it a good unit, do I need to install the castle bec unit. Last but not least I want to know if I can run my receiver and servos off the main battery (a 7.2 NIMH) instead of a receiver pack. But what I have read the castle bec and esp can step down the voltage to be safe for servos. I would also buy the castle link for programmability. The receiver is a spektrum sr3000 I know its long :shock: Sorry |
Rooster crawler or Tekin rebel 2 are both good choices. With either you will not need a external bec. |
tekin fxr...if you stay brushed |
had Tekin Rebel 2, the bec good enough for support my 5.75lbs crawler, but no drag brake or full brake though..forward i'm looking for cc sidewinder or tekin fxr |
x2 for the Tekin FXR (if staying brushed) |
the only problem with the tekin FXR is the price for it and the hotwire kit. (the castle link is sold on ebay for $1) Also can i run my servos off of the main battery how would I do this? will a esc step down the 7.2 volts to 6 volts to be safe |
I have two sidewinders and am getting ready to order one or two more. I've heard alot of good things about the Tekin FXR but for now I'm gonna stick with what I know. If I remember right the internal BEC on a sidewinder is somewhere around 5.1v, so your servos will be fine, but I like having the CCBEC so I can bump it up to 6v. Get the Sidewinder and the Castle Link, and then you can use the same link if you ever decide to put the external CCBEC on it. |
the sidewinder is a great esc, I have two. the bec is a little weak, 5.1 volts, and I thing 1.5 amps. a ccbec is a must. I have never owned a tekkin and probably never will, only 'cause I would have to order it online and I like supporting my local hobby shops. also the programmability of the sidewinder is amazing with the castle link! "thumbsup""thumbsup""thumbsup" |
