Thread: aa nimh 2500 charge amp?
Old 06-30-2008, 11:26 PM   #1
Default aa nimh 2500 charge amp?
I have an 8 cell AA nimh pack that I made. They are 2500 mah cells. What would you charge them at? 1 amp or? I dont know what they should charge at. Thanks for looking
topdog909 is offline   Reply With Quote
Old 06-30-2008, 11:57 PM   #2
cherokee95's Avatar
1 amp souds about right, laess if you have time. Much above 1-1.5 amps and small cells tend to build up too much heat.
cherokee95 is offline   Reply With Quote
Old 07-01-2008, 06:59 AM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Yeah, the AA cells have a pretty high resistance in relation to other cells. 1 amp max IMO, I would charge at .5a to be on the safe side. What brand cell are they?
JohnRobHolmes is online now   Reply With Quote
Old 07-01-2008, 08:59 AM   #4
That's good info there... I was thinking about picking some up... curious to see what type you are running.
darkstar is offline   Reply With Quote
Old 07-01-2008, 09:25 AM   #5
I get much better charges out of my AA Nimh batteries when I use lower rates, in the .6 amp range. I usually cycle them twice, with discharge rate 1/2 of the charge rate, and the mAh usually goes up to maximum. Any faster, and they only get 2/3 or 1/2 charge.
Master Basher is offline   Reply With Quote
Old 07-01-2008, 11:15 PM   #6
I have a few sets of duracell aa and i charge them at .6a, it takes a while but they charge great and last a long time. 2550mah
AWILLIAMS64 is offline   Reply With Quote
Old 07-01-2008, 11:30 PM   #7
they are energizer nimh 2500 thanks for the help guys i will charge them at .5 amp
Old 07-02-2008, 07:27 PM   #8
OK I charged them at .5 amp, took about 2 hours, didn't even get warm and works perfect. Thanks again
