| | #1 |
| Rock Crawler Join Date: Jun 2006 Location: Maryland
| I need all the power I can get to turn these new 40 series Rock Crushers. I think Im only getting half the power I could be using. My current setup consist of... *2 cell li-po *Mamba max ESC * JR FM receiver *2 into 1 splitter to feed both servos from 1 receiver port ( I think this is my main problem) *2 JR st125 servos. The mamba puts out 5v (?) and my splitter divides that to 2.5volts... I think. What do I need to do to get 6 volts to my servos... Thanks -Brian |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
| Seems like I post this same answer 4 times a week, but.....................get a Castle BEC. A MM doesn't have enough juice for 1 servo, much less 2. Get the BEC, set it up for 6-6.5 volts and you're golden. It has up to a 10 amp output. It takes a Castle Link to set the voltage so you'll need to buy or borrow one or get it from Holmes Hobbies on here and he'll set it for you for a very small fee. It comes default at 5.1 volts. And your 5 volts doesn't get split into 2.5. Last edited by Scattman; 07-01-2008 at 09:54 AM. |
| | #3 |
| Rock Crawler Join Date: Jan 2008 Location: Arlington, TN
| plug the cc bec + - wire to your servo and plug just the signal wire into the rx, this allows max power to the servo depending on what the cc bec is set at |
| | #4 | |
| Rock Crawler Join Date: May 2007 Location: lacey
How would the servo get a singnal to turn? the bec would, but not the servo. I guess I need a diagram. Second, GET STRONGER SERVOS. a 125oz/in servo will get you by in a 2.2, but with 40's, your going to need at least 200oz/in of torque, preferably 300+. Third, get a bec set to 6+volts all of this and you are golden, and like scattman said, a Y only puts the two servo's in parallel, not series, so the voltage is the same. not halved. Don't go skimpy on your servo's, TRUST ME. you will be alot happier with a couple of 80-115 dollar servers that rock and will last compared to a $20 servo that will last a couple of weeks. Whoever said money doesn't buy happiness didn't play with r/c trucks! | |
| Thread Tools | |
| Display Modes | |
