| | #1 |
| Quarry Creeper ![]() Join Date: Sep 2005 Location: Lufkin
| I did a search and am still confused. I am running a Tekin FXR, CCBEC, Integy 65t motor, JR 8711 servo on my ax10. My question is, since I want a 3s 2100mAh or bigger battery, what C rating should I look for? I've read some that say 10-15 and some that say 20 or greater. What's the consensus? |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Dec 2005 Location: Hawthorne, Florida
| I would say a 15c at least. I like to run 20c packs when possible. |
| | #3 |
| Quarry Creeper Join Date: May 2008 Location: ncrccrawlers.com
| I have seen people recommend 30A continuous because in a crawler you should never need that much amperage. With your 2100mAh lipo you find what C rating you want by taking the C rating (15) times battery Amps (2.1A) = 31.5A. |
| | #4 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| Double ditto. 30a continuous is a great starting point for a long lasting battery (cycle wise). The 65t won't quite need much more than a 20 or 25 amp pack, but the more overhead you have on your lipo the longer it will last. |
| | #5 |
| Well I'll start shopping for at least a 15C pack. I appreciate the info. |
| | #6 |
| RCC Addict Join Date: Dec 2004 Location: HELL.....
| generally its not hard or more costly to find a 20-25c pack. so you can better utilize it in the future and have a longer life i would keep it 20-25c |
| | #7 |
| I ended up ordering a polyquest 3s 11.1v 2100mAh 18c battery. |
| | #8 |
| Rock Crawler Join Date: Apr 2007 Location: Denverish
| I've got the 2500mah version of that pack. So far, so good. |
| Thread Tools | |
| Display Modes | |
