Thread: wire shielding materials?
Old 07-02-2008, 04:41 PM   #1
Default wire shielding materials?
Is anyone using wire shielding? If so, what are you using?
I'm looking to use some kind for my AX that is glitching like crazy still. I have replaced everything but the Rx and figure I am getting it from wires too close to each other and the antenna. I'm starting with twisting them then want a RF shield.
Mule is offline   Reply With Quote
Old 07-02-2008, 04:50 PM   #2
You can use ferrit loops. They are the black rings that look like a magnet that you will find inside some electronic devices. You can buy them at rat shack.
CrawlinClodKiller is offline   Reply With Quote
Old 07-02-2008, 05:30 PM   #3
They aren't always black, they can be any colour. Find a power supply, rip out a coil, and cut all the wires of the coil. You will be left with a ferrite ring.
Pretty much anything that changes voltage has a ferrite ring in there somewhere. Power supply's, battery chargers, transformers, etc
HndsWthtShdws is offline   Reply With Quote
Old 07-03-2008, 09:33 AM   #4
I had a bunch or those laying around for years. Now, to find them will be fun...
Thanks - good idea.
