Thread: stupid me
Old 07-03-2008, 11:30 AM   #1
Default stupid me
will the Rooster Crawler handle 8cell nimh pack? i wasnt thinking to check the voltage rating B4 i ordered the battery. i could exchange for a 7 cell, but will the 8 cell work
wojin is offline   Reply With Quote
Old 07-03-2008, 11:34 AM   #2
maybe, it is only rated to 7 cells though.
mysharona is offline   Reply With Quote
Old 07-03-2008, 11:42 AM   #3
Slow_Joe's Avatar
You will smoke the ESC with 8 cells. Trust me.... I know from experience
Slow_Joe is offline   Reply With Quote
Old 07-03-2008, 11:42 AM   #4
Dream...Think...Create.
Nova's Ark's Avatar
If you pull the red wire out of the harness going into the RX, you might be OK. By doing that, you will disconnect the internal BEC on the Rooster Crawler. You will then have to run a separate stand alone BEC like a Castle Creation BEC or something similar. A lot of the heat and problems caused in ESC's come from high voltage having to be converted lower by the ESC's BEC to run the RX and servos. You should check with Novak to be sure though. They put those voltage limits on the Rooster Crawler for a reason.
Nova's Ark is offline   Reply With Quote
Old 07-03-2008, 11:52 AM   #5
MadDogRC LLC
Mad4Rnr's Avatar
^2X
I read a tread once that said the same thing about pulling the red wire and running an external BEC. Also just becareful with 3C lipo as the cutoff will not be set corrctly
Mad4Rnr is offline   Reply With Quote
Old 07-04-2008, 02:57 AM   #6
im just gonna return it and just get a 6 cell
