06-30-2008, 07:01 PM | #1 |
Rock Crawler Join Date: May 2005 Location: Minnesota
| New CC BEC, MM ESC not working?
I just got my CC BEC today and got it all wired up. The ESC has the red wire remove(like stated in the directions). I have the BEC plugged in though a Y harness in the throttle channel on the RX. I'm running a Spectrum SR3000. I got it to the point where the servos work, but no throttle. When I turn on the ESC on it flashes all three lights, rings three time(I'm running a 3S lipo) and then just flashes the three lights steady. The three lights don't stop flashing to arm the ESC. Anyone have any ideas? I'm running a mamba max, Spectrum SR3000 RX, 3S lipo, Towerpro 945 MG and scorpion 3014. I called Homles Hobbies with no answer. |
06-30-2008, 07:34 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
make sure all your endpoints are set correct, trims set to 0, etc...then reprogram the esc
06-30-2008, 07:45 PM | #3 |
06-30-2008, 08:17 PM | #4 |
| no...make sure the orange wire on the esc is in fact connected........next put the red wire back on the esc plug and remove the bec.....then program the esc. it sounds like the esc isnt programmed correctly....make 100% sure your epa are set to max and your trims are at 0....does the esc program at all?
07-01-2008, 06:00 AM | #5 |
Did you go through the quick setup and get your throttle enpoints set? If all three lights are blinking then you aren't getting radio signal to the ESC. Steering servo works? You must have called at a weird time, I was around the phone from 8am to 6pm yesterday all day. |
07-01-2008, 08:49 PM | #6 |
Pebble Pounder Join Date: May 2005 Location: san francisco
Kinda dumb, but make sure your motor is plugged in correctly, I have had similar results before.
07-01-2008, 10:21 PM | #7 |
Quarry Creeper Join Date: Nov 2006 Location: San Jose
07-01-2008, 10:24 PM | #8 |
Rock Crawler Join Date: May 2007 Location: lacey
Also try pulling the signal wire from the BEC. sometimes they can cause issues. I have had NO problems running my dual sidwinders w/ccbec on my super, and I am runnning the most wicked wiring harness that is beyond imagination.
07-02-2008, 02:37 PM | #9 | |
It's all good about the phone call, we're all very busy people. | |
07-02-2008, 02:54 PM | #10 |
As long as your RX doesn't heat up or you don't experience glitching, running the power through the RX can work just fine. You may just check out the Y harness to see why you weren't getting signal, maybe a loose pin.
07-03-2008, 02:51 PM | #11 |
| I've been planning on looking through my home made Y harness and seeing what is not working. I cant see why it's not working though.
07-04-2008, 10:11 AM | #12 |
I went through the Y harness and it's now working. I'm not sure what happened. I'm thinking the wires were touching, so individually shrink tubed them. Works great now, thanks for the help guys!
07-04-2008, 10:20 AM | #13 |
Pebble Pounder Join Date: Dec 2007 Location: Torrance
The CC BEC is supposed to be connected directly to the Batt port on your RX. Why do you need to run it through a Y harness?
07-04-2008, 10:25 AM | #14 |
maybe to power his servo's directly so as to not harm rx? thats what I did.
