Thread: Cobalt w/3s?
Old 07-04-2008, 02:01 AM   #1
Default Cobalt w/3s?
Looking at picking up a HH Cobalt (still). JRH's site states they're rated for 5-10 volts, but how are they holding up for everyone running them with 3s lipo @ 11.1? Are the 7t still driveable with good fine control on the rocks?
Mortimer Snerd is offline   Reply With Quote
Old 07-04-2008, 02:44 AM   #2
Havent had a single problem. I have a 10T Puller on 3S lipo with a Mamba max in my super and a 7T puller on 3S with Sidewinder (had been a super rooster) in my 2.2. Had some low speed issues with the 2.2 when I was using the Super Rooster ESC, but not a single issue now with the Sidewinder. Gear down and Volt up as JRH says...
Just grab a Puller, add 3S power and either a Mamba Max or Sidewinder, slap a CCBEC in and enjoy!!! Just beef up the rest of your drivetrain
bustedcrawler is offline   Reply With Quote
Old 07-05-2008, 05:39 PM   #3
I have a 7T with a 12t pinion on a 3s lipo using a tekin FXR . You might have to watch your motor temp, it can get HOT. JRH said 160F is the max temp. It all depends on how you drive. I love it ! super smooth slow control and crazy wheelspeed. Best brushed combo ever ! I recommend a BEC with ANY esc, it takes the extra stain off of the esc. You will break parts !!!! highly recommend slipper clutch. I stripped the stock AX-10 rims with the slipper little too tight. The 7T has crazy torque, you will love it ! well worth the price and wait !
toytech93 is offline   Reply With Quote
Old 07-06-2008, 12:16 PM   #4
DOOH!!!
MTHead's Avatar
10T puller, 10 2/3cells, and a Mamba Max running through a Ax10 tranny w/13t pinion and VF dig. Great low speed crawl and enough wheel speed to jump gates. Definitely watch the motor temps though, she gets warm.. Torque = broken/sheared front outputs, x3
Best brushed motor i ever bought!!!
MTHead is offline   Reply With Quote
Old 07-06-2008, 12:21 PM   #5
The Real Dogman's Avatar
Fo Sho!!! A cobalt is just too much motor in my opinion due the numerous broken parts, but many enjoy the wheel speed on tap!! Good Luck!!
The Real Dogman is offline   Reply With Quote
Old 07-06-2008, 12:33 PM   #6
that is a great combo if you want to jump stuff.hahah
jamesdicken is offline   Reply With Quote
Old 07-06-2008, 12:47 PM   #7
TEAM MODERATOR
Reflection's Avatar
5 turn,I wouldn't run anything more than 8 cells. I've run a 5t on a 3 cell. No doubt,it's VERY fun.....BUT,you gotta watch the temps. They'll get warm very quick on a 3 cell. You'll also need a lipo that can handle very fast discharge. These cobalts like power,but they'll dish it out also.
7 turn,They'll handle the 3 cell good,but I think they'll be happier at high voltage with a lighter rig and lower gearing.
10 turn,I've run my 10 turn on a 3 cell and run it HARD. Final gear ratio is 38:1 so it's geared kinda high. Still crawls like a champ at slow speeds but will GIT IT when needed.
There's no such thing. Just add bulletproofness.
Reflection is online now   Reply With Quote
Old 07-06-2008, 12:55 PM   #8
Prick
rambuller84's Avatar
I've got a 7T/mamba max running on 14.4V and it's awesome. If you gear down enough the temps aren't too bad. I'm getting a small fan for mine in the future.
rambuller84 is offline   Reply With Quote
Old 07-06-2008, 08:35 PM   #9
7t 3s with mamba and ccbec and i have great lowspeed and nice wheelspeed. i couldnt think of a better combo
BILLYGOAT is offline   Reply With Quote
