Thread: New esc
Old 07-04-2008, 10:36 AM   #1
Default New esc
Well looking to amp up the electronics on my ax-10 rtr. I wanna go with a cobalt 7t and was wanting some in put on what esc to get. I heard the mm is good but how hard is it to program it to run brushed? Because dont it come brushless? Or what are some other good esc that will hold up the 7tm power?
hummer6504x4 is offline   Reply With Quote
Old 07-04-2008, 01:31 PM   #2
I run the 7T....get an FXR
Deezul is offline   Reply With Quote
Old 07-04-2008, 02:53 PM   #3
But i thought the fxr was only rated down to a 12t or somthing. Sorry still a newb and trying to figure stuff out.
Old 07-04-2008, 03:02 PM   #4
TEAM MODERATOR
Reflection's Avatar
12t 3 pole motors. The pullers are 7 pole motors. Should be safe to run.
Personally,I like the Castle stuff. It's VERY simple to program and set everything the way you want it.
Reflection is offline   Reply With Quote
Old 07-04-2008, 04:36 PM   #5
I have looked for the castle MM. And every one is sold out of them. Do you know who has them in stock.
Old 07-04-2008, 06:29 PM   #6
FXR can run a 7t w/out even heating up. There is the PRO too. Very easy to program either and it runs silent. I went with it because of the noise I have heard on CC stuff.(screeeeeeeech)
Old 07-05-2008, 12:39 AM   #7
I have a sidewinder and a mamba max, both are powering Pullers (1x 7T and 1x 10T), with CC BECs and 3S lipos. Castle stuff is SUPER easy to program and well worth having to wait for more stock to arrive in IMHO.
bustedcrawler is offline   Reply With Quote
Old 07-05-2008, 06:05 AM   #8
2D
Harvo's Avatar
I'm going to the FXR when I bump up to 3s lipo. I have heard lots of good things and it's small... plus it has a built in BEC.
Harvo is offline   Reply With Quote
Old 07-05-2008, 06:57 AM   #9
I am using the CC MM with a 7 turn puller and 3S lipo... nice wheel speed and still able to go as slow as you want. It does make a whistling noise at part/low speeds, but nothing crazy. Under the Holmes Hobbies vendor section is some more information about the 7 turn puller. JRH says it is roughly the same as a 540 27 turn for resistance.
The MM comes with a USB cable and is super easy to program. The Sidewinder you have to program with the radio, or get the Castle Link to hook it up to the computer.
Knotaddicted is offline   Reply With Quote
Old 07-05-2008, 09:16 AM   #10
TEAM MODERATOR
Reflection's Avatar
You should be good with either the Sidewinder or the Max. RCP Crawlers has then in stock.
