Thread: novak rooster crawler combo problems
Old 07-04-2008, 08:01 PM   #1
Default novak rooster crawler combo problems
im pretty sure i have it all wired correctly, but i have no reaction from it. following the instructions, after the red light turns on i let go of the button and the red light stays on. no throttle control is gained and i have no power to the servos.
any ideas?
wojin is offline   Reply With Quote
Old 07-05-2008, 09:09 AM   #2
any ideas?
After you let go of the button on the ESC you are supposed to pull the throttle to full on position until it turns solid green. I had the same problem a couple days ago after i left off of the button and then I would pull full throttle I never got a green light. The wire going from the ESC to the Rx was backwards. Just flipped it around and it works fine.
robert97dodge is offline   Reply With Quote
Old 07-05-2008, 03:33 PM   #3
ill check it out
Old 07-06-2008, 01:29 AM   #4
one reply, one correct answer to the problem, thanks alot robert. runnin like a champ now
