| | #1 |
| Rock Stacker Join Date: Apr 2007 Location: Philippines
| Hi guys, I have a clod build going..I plan to use two 540 stock silver can motors in series. However when everything is connected, one motor seems to turn slower than the other.. I tried getting a diffrent silver can but still the same result.it slows down t o a halt while the other motor is still turning. What could cause this? Is there a regulator needed of some sort. I built LED foglights in series before and I noticed over time, one bulb eventually weras out more than the rest? Could this be related and be applicable even by analogy to my motor problem? Thanks in advance Edward |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| Wired in parallel is the most common, and advantageous, means of wiring two motors in a crawler. Is there a particular reason you are going with series? |
| | #3 | |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
I believe the theory with series wiring is that if motor 1 sees an increase in load, the current flowing through it decreases and the voltage drop across the motor decreases. Since the total voltage drop (motor 1 + motor 2) must remain constant, the voltage drop across motor 2 increases, as does the current flowing through it. This makes motor 2 spin faster. I may be shaky on my theory but I do know for a fact that increasing the load on one motor increases the speed of the other motor. I've tried it and it does not work for crawling with a Clod type axle. If both motors were driving a common gear, it works fine. Clods should always be wired in parallel for crawling. | |
| Thread Tools | |
| Display Modes | |
