Thread: crazy glitching
Old 07-07-2008, 01:55 PM   #1
......../-__-\........
helhedded's Avatar
Default crazy glitching
My servo never glitches. With my finger off of the throttle, my rig will jump into reverse for half a second. It will also jump into reverse repeatedly (or the signal just drops) while I'm going forward.. the speed where I am when it does this varies.
What I'm working with
ckrc 6-cell 1500 split pack
novak 55t
Hitec Agressor 2-chan
Hitec 645 servo
CC sidewinder
my RX antenna is really long, but it doesn't touch any metal. Do I need the CC BEC??
I can get some pics of my rig tonight when I get home.
helhedded is online now   Reply With Quote
Old 07-08-2008, 05:03 AM   #2
before I bought my sidewinder I called castle and asked them if I needed the ccbec when running one hitec 645, they said yes. I don't know if will cure your problem,but thats where I would start, the sidewinder has a wimpy bec, so its probably cutting out while trying to keep your servo centered.
allgm1 is offline   Reply With Quote
Old 07-08-2008, 08:31 AM   #3
helhedded's Avatar
I'm planning on getting one of those in a couple of days. We will see how/if it helps.
This is my current set-up. I did move my servo wires away from my esc wires, and I twisted my battery wires too. It seemed to help, but I still got some glitching while going forward. The violent magical reversing seemed to go away. I will test it out some more tonight.
Old 07-08-2008, 05:16 PM   #4
1rcmonster's Avatar
I would direct wire the motor and put a couple of twist in the wires as well, helps to cut down on radio noise....also try to keep all servo and esc wires away from your motor, motor wires and battery wires, they can pick-up interference if running close by...hope this helps
1rcmonster is offline   Reply With Quote
Old 07-11-2008, 09:29 AM   #5
helhedded's Avatar
Well I went by one of my LHS's yesterday and picked up the CC BEC. WOW!! My servo is faster, and my motor is faster. The glitching only seemed to get worse, though. Is it possible for wireless internet signals to mess with my radio? I'm starting to think my Hitec Aggressor 2-channel is mainly the reason for this off-the-wall glitching. The ESC still goes nuts.
me=frustrated
Old 07-11-2008, 09:44 AM   #6
do you get more glitching int he house or out side? when i used a non 2.4 radio i got more glitching int he house rather than out side. its hard sometimes to ge the glitching out of a am radio....
mudboger07 is offline   Reply With Quote
Old 07-11-2008, 09:52 AM   #7
helhedded's Avatar
It doesn't matter where I am, or how far I am from my rig. It took 10 minutes of driving for it to glitch at the Hobby Shop yesterday.
Old 07-11-2008, 09:54 AM   #8
helhedded's Avatar
The sheet that comes with the BEC says to keep it away from recievers and the esc. there isn't much room to do that!!
Old 07-11-2008, 09:59 AM   #9
Ive had mine mounted within a 1/4" of the esc and the rx before with no problems, I know you might not be ready yet but a 2.4 will fix all of that......
Old 07-11-2008, 10:03 AM   #10
helhedded's Avatar
yeah I know... :-(
which one? the DX3r? I'm trying to remember which one you told me about
Old 07-11-2008, 10:41 AM   #11
helhedded's Avatar
this isn't the dx3r, but would it work good without any glitching?
http://cgi.ebay.com/Spektrum-DX3-Tx-...QQcmdZViewItem
Old 07-11-2008, 10:48 AM   #12
Yes, any 2.4ghz system will stop the glitching.
darkstar is offline   Reply With Quote
Old 07-11-2008, 10:56 AM   #13
helhedded's Avatar
I just found a Dx3 used for the low low, locally. :-P:-P:-P:-P:-P
Old 07-11-2008, 11:24 AM   #14
i have a dx6i and i have the second reciever under the esc and next to the ccbec and get no glitching
twin recievers cure all glitching ive found
bluelightning is offline   Reply With Quote
Old 07-11-2008, 11:26 AM   #15
my SR3100 is sitting about 1/8" from my GOAT ESC, and I have never had problems with glitching, and my antena runs along side the aluminum side panels on my tuber.
Old 07-11-2008, 12:36 PM   #16
helhedded's Avatar
well I just picked up a used dx3 and a new reciever. I will report back after the install.
Old 07-11-2008, 12:40 PM   #17
Good... you should notice glitch free operation from now on
Old 07-12-2008, 09:54 PM   #18
helhedded's Avatar
you sure said it. no glitching whatsoever. am radios should be outlawed
LESSON TO NOOBS LIKE MYSELF.... SAVE YOUR MONEY AND TIME AND JUST BUY A SPEKTRUM.
Old 07-12-2008, 09:58 PM   #19
Practicing my launchs >:)
Robbob's Avatar
think how us old timers had it before even the PCMs came out ..... sittin at a start grid and stutter off the horn. Those where the fun days lol.
Robbob is offline   Reply With Quote
