Thread: Bec with Goat
Old 07-07-2008, 08:25 PM   #1
Default Bec with Goat
Can I run an additional Bec with the built in one in the Goat system? Such as the cc bec so that I can adjust the voltage.
rc4x4crawler is offline   Reply With Quote
Old 07-08-2008, 11:53 PM   #2
yes. I am running a Goat with the CC- BEC Powering a JR DS8711 (steering) & HS225MG (DIG).
Pull the RED wire coming from the Goat ESC connector (Tape the free wire end with electrical tape).
Plug the connector into the Throttle channel of your RX (Black & White).
Plug the connector coming from the CC-BEC into the Battery channel of the RX.
Flynfrog
Flynfrog is offline   Reply With Quote
Old 07-09-2008, 10:04 AM   #3
Flynfrog
Oh thanks I have ran Bec's before I just needed to know if they worked with the goat. Thanks
Old 07-09-2008, 10:05 AM   #4
Technically it is not in "addition" it is "in place of" the Goats BEC
or im totally wrong
by pulling the red wire going to the Goat you are eliminating the Goats BEC
Jeepernick is offline   Reply With Quote
Old 07-09-2008, 12:52 PM   #5
or im totally wrong
Ok that makes sense. Then you are adding your own Bec. I got it. Thanks guys.
