| | #1 |
| Rock Crawler Join Date: Aug 2007 Location: Atlanta
| can you submerge a lipo in water? thanks! |
| Sponsored Links | |
| | #2 |
| Pebble Pounder ![]() Join Date: Apr 2008 Location: SE Sodak
| all the paperwork says no, that being said I run a 2s lipo in my water proof 18mt in the winter and have submerged it several times with no problems and I have a 3s in my F350 and have submerged it a couple times ( not deliberately ) also no problems. I still wouldn't recommend it , I may be lucky and don't want you to come after me when your rig goes up in flames! |
| | #3 |
| Rock Crawler Join Date: Dec 2005 Location: West Omaha
| lithium becomes highly explosive when wet. take your chances. |
| | #4 |
| RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
| Getting splashed with water in many cases is fine. Submerged in water is not good. The problem is that where the tabs exit the cells there is a thin foam seal if water were to soak past that then yes you will have a problem. In most cases if your affraid of your Li-Po getting wet in a scaler I would suggest a large balloon wrap or a zip lock baggie with a corner cut for the wires to exit. The a littel silicone to seal up that exit hole and the wires. We have a lot of customers that run Li-Po's in there boats and they get wet quite often but I have yet to hear of any major issues. But be aware that it could happen. Take care, Jason |
| | #5 |
| Newbie Join Date: Aug 2007 Location: England
| Lithium does react violently with water, id say risky. |
| Thread Tools | |
| Display Modes | |
