Thread: rooster crawler on 8.4 volts?
Old 07-08-2008, 12:02 AM   #1
Default rooster crawler on 8.4 volts?
i have a rooster cralwer esc and ordered a 7 cell 8.4 volt split pack. is anybody else running this setup? any problems? do you like it? esc handles it ok? let me know what you think....
topdog909 is offline   Reply With Quote
Old 07-08-2008, 12:12 AM   #2
Just built a crawler for a friend and put the 7 cell packs on it with the Rooster and 55T motor. I had the same setup but with 6 cell pakcs and I will for sure be upgrading to the 7 cell packs very soon. It is well worth it for a couple bucks more and had no problems.
robert97dodge is offline   Reply With Quote
Old 07-08-2008, 01:05 PM   #3
vipxj's Avatar
thanks you also answered my question
vipxj is offline   Reply With Quote
Old 07-08-2008, 01:35 PM   #4
Mriswith's Avatar
I've been running the Rooster Crawler/55t combo on TCS's 6 and 7 cell split packs. Works great and I haven't any problems with mine.
Mriswith is offline   Reply With Quote
Old 07-08-2008, 01:42 PM   #5
thanks guys keep them coming!
Old 07-08-2008, 01:50 PM   #6
I have 8 cells on my Rooster Crawler. I love the power. No problems at all!
chops1sc is offline   Reply With Quote
Old 07-08-2008, 02:38 PM   #7
I joined the Band!
im running a 9.6v aa pack on my crawler combo and it has no problems drives like a champ
2fknqwk is offline   Reply With Quote
Old 07-08-2008, 05:06 PM   #8
1rcmonster's Avatar
I am running a rooster crawler and 7 cell 2/3a pack with a 55 turn motor...the brakes are great on that speedo and the throttle is nice and buttery smooth.....
1rcmonster is offline   Reply With Quote
Old 07-09-2008, 07:17 PM   #9
vipxj's Avatar
I thought you could run 8.4 /7cell max through a rooster crawler ,thats what it says in the instuctions?
Old 07-09-2008, 07:20 PM   #10
Beef Tube Supplier
biggin69's Avatar
It does say that 7 cells is the max for this ESC. The Tekin FXR can handle up to 9.
biggin69 is offline   Reply With Quote
Old 07-09-2008, 08:10 PM   #11
im runnin a 7 cell on my rooster and its awesome. got great punch when u need it...
also im runnin 20c lipos also, but am havin trouble turnin the lipo cut off on, i cant access the 3rd and 4th profile as stated in the instructions...
any help guys
MSF17 is offline   Reply With Quote
Old 07-09-2008, 08:27 PM   #12
TEAM MODERATOR
EeePee's Avatar
any help guys
There's a little piece of paper included with the ESC, there aren't any 3rd and 4th profiles in the Crawler version.
EeePee is offline   Reply With Quote
Old 07-09-2008, 08:43 PM   #13
2D
Harvo's Avatar
So does that mean it doesn't have a lipo cutoff?
Harvo is online now   Reply With Quote
Old 07-09-2008, 08:56 PM   #14
I joined the Band!
profile one is non lipo
Profile two is lipo
Old 07-09-2008, 08:58 PM   #15
Yes, the Rooster Crawler has Li-po cutoff. A few months back, Novak started putting a addendum in the package.
The Rooster Crawler has 2 throttle profiles.
Parameter Profile1 Profile 2
W/reverse yes yes
% reverse 100 100
Drag Brake 90% 90%
Li-Po cut-off Disabled Enabled
2 blinks of the red LED will enable Li-Po cut-off.
Greg B. is offline   Reply With Quote
Old 07-10-2008, 07:52 PM   #16
Default Cell Limit?
Documentation says 7 cell on the rooster.
How many are running 8 without any problems?
Any temp issues pushing it to 8?
hcssbd is offline   Reply With Quote
Old 07-11-2008, 12:08 AM   #17
no temp issues on 7 that i could note. i was using my neighbors Promatch Matched (when new) 7cell made from ib3800s. got well over an hr of runtime, maybe closer to 1 1/2 maybe 1 3/4 time with the rooster/55t. the heatsink was barely even noticably warm.
Timmahh is offline   Reply With Quote
