07-15-2008, 11:04 AM | #1 |
Rock Crawler Join Date: Apr 2007 Location: Nor*Cal
| Spektrum Receivers
Does the DX3, DX3.0 and DX3R all use the same receivers?
07-15-2008, 11:13 AM | #2 |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
| they don't come with the same but you can use either receiver with either radio ...i'm actually using the receiver(sr3000) from my DX3 with my DX3R because you can cut the antenna down to 3.6" on the older receivers but you can't cut the antenna wire on the new receivers(sr3100) that comes with the DX3r
07-15-2008, 11:25 AM | #3 |
Good to know, thanks!
07-15-2008, 12:56 PM | #4 | |
Rock Crawler Join Date: Jan 2008 Location: Knoxville
07-15-2008, 01:41 PM | #5 |
| no...you can cut the antenna to 3.6.....the only thing it mentions about cutting the antenna tube is that you would want to cut the tube so the antenna sticks out at least a 1/2" past the end of the tube
07-15-2008, 02:58 PM | #6 |
Rock Crawler Join Date: May 2007 Location: lacey
The DX3R is the only one that can use the sr3100, but the other receivers all work with all the radios, minus the aircraft radios.
07-18-2008, 09:52 AM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
The DX3R is DSM2 and the other radios are DSM. DSM2 radios are reverse compatible but not the other way around.
07-19-2008, 09:38 AM | #8 |
RCC Addict Join Date: Jun 2008 Location: Fresno
can i use other brand dsm recivers w/ the dx3r? do the recivers need to be 3 channel ? can i just use 2 channel recivers? i ask because im thinking about getting rid of all of my rtr 2 channel radios (which are utter crap) |
07-20-2008, 09:09 PM | #9 |
Newbie Join Date: Apr 2008 Location: DeBary
if you get a spektrum radio, you must use a spektrum receiver, they dont interchange like some fm and am stuff
