07-17-2008, 10:03 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: Garden State
| Lithium Magnessium
Hey guys I just wanted to turn some people on to these packs. They are safer than li-po and just as powerful. check'em out. www.pfmdistribution.com/ The sizing on these packs are perfect for crawlers look at the 2000mah short receiver pack
07-17-2008, 10:36 PM | #2 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
| This packs Maximum Continuous Discharge Amperage: 5A (2.5C) Not good for a crawler |
07-17-2008, 10:50 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: akron
the RX packs are a little on the weak side.. but there other packs are great |
07-17-2008, 10:54 PM | #4 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| on th4 1500 3 cell I see 30A or 20C.........I believe that is the max charge rate
07-17-2008, 11:12 PM | #5 | |
Pack Specifications: * Capacity: 2000 mAh * Dimensions: 30Wx48Lx32T (1.22"x1.96"x1.31") * Weight: 94 Grams (3.36 Oz) * 20 Gauge Silicon Wire Leads Operating Specifications: * Maximum Charged Voltage: 8.4V * Minimum Discharged Voltage: 6.0V * Maximum Charge Amperage: 2.0A * Maximum Continuous Discharge Amperage: 5A (2.5C) | |
07-18-2008, 08:12 AM | #6 |
| I am kind of lost when it comes to batteries, Why do we need high discharge amperage? I thought that just applies with your charger when cycling your batteries. Is 5A the amount of power when active.
07-18-2008, 08:51 AM | #7 |
Quarry Creeper Join Date: Feb 2008 Location: stockton
apogee ya if you look at the site they got 20c with big wire on them. i run there 2200mah 2 cell and get about 2 hours of straight run time no stop. they are very safe and no balancing, i have turned alot of people towards these. i think best battery hands down. |
07-18-2008, 09:00 AM | #8 |
same charge as Lipo?
07-18-2008, 09:08 AM | #9 |
07-18-2008, 09:19 AM | #10 |
| An RC crawler draws amperage for use in the radio equipment, the servos, the motor, the esc, they all draw power and 2.5C is not near enough power to run them all, for a 2.2 with single esc, low draw motor, sinigle servo a 10C will work fine. but the more equipment you put on board the higher amp draw you have so the higher battery discharge rate you need. a super will need even more draw rate. Im running 2/3A cells that discharge at 20C continuous and its barely enough
