07-29-2008, 09:54 AM | #1 |
Pebble Pounder Join Date: Jul 2007 Location: Herent , Belgium
| wich motor???
i am getting a rc4wd tranny on my scaler but in combination with a novak 55t motor it doesn t have no speed anymore , what motor should i take to have still enough torque + some more speed , any sugestions anyone |
07-29-2008, 10:02 AM | #2 |
Rock Stacker Join Date: Jul 2008 Location: Under A Rock
Call John at HH,he will help you out. http://holmeshobbies.com/home.php |
07-29-2008, 03:58 PM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
I would say the HH-HHH30 or 35 from Holmes Hobbies. |
07-30-2008, 02:25 PM | #4 |
Rock Stacker Join Date: Apr 2008 Location: Tucson
| puller
you could do a puller motor from holmes.
07-31-2008, 01:10 AM | #5 |
That puller motor is one hell of a beasty engine , but I think I go for the 35T solution Thanks for the info guys |
07-31-2008, 01:48 AM | #6 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Add more volts to the equation. If you geared down the the R2, volt up with a bigger pack. Are you running a 6-cell now? Try an 8 or 9 cell... ONLY if your ESC will work with a bigger pack.
07-31-2008, 09:09 AM | #7 |
varcor.org Join Date: Aug 2005 Location: 757
I agree, instead of trying another motor. Try a different pinion or volt up. Which ESC are you running? On the R2/R2D I had, I ran an Axiom 50T motor with a 22T pinion (I think somewhere around there) and saw an improvement over the stock pinion that comes with the R2/R2D. The biggest improvement was jumping to the 8-cell pack. |
08-01-2008, 01:08 AM | #8 |
my esc is a traxxas xl5 so i think it can t hold 8 or even 9 cell battery packs + i haven t got the space because I rejused the battery holder from my wheely king and all the rest of my homemade scale chassis is packed up with other stuff , I could try with the gear ratio to , thanks alot for the info dudes
