Thread: Question on TQ3...
Old 07-29-2005, 07:52 PM   #1
Default Question on TQ3...
Hey is there any way i can hook channel 1 and 3 both to the steering pot and have FULL steering. i did try putting the three wires from channel 3 to the steering pot (along with channel 1) and i only got about half the movement of the servos...
SO i pretty much want to be able to have ch.1 and ch3 hooked up to the same pot and have full throw.
nd4spdbh is offline   Reply With Quote
Old 07-29-2005, 08:32 PM   #2
Colt Python/SR9c
TwistedCreations's Avatar
got a litle lost, but it seems the channels would counteract. unless you have your servos set EXACTLY the same.. but maybe it's just lack of sleep as to why i got lost..well i do all the time anyway..but if you installed pots on channel 1, why not take the time and do it on channel 3?
TwistedCreations is offline   Reply With Quote
Old 07-29-2005, 11:10 PM   #3
well what i pretty much want to do is mix channels 1 and 3... sort of like this controler http://www.rcbackyard.com/utq3.htm
Old 07-30-2005, 10:24 AM   #4
help!!!!!
Old 07-30-2005, 01:05 PM   #5
just get a y-harness, so channel 1 will work both servos
colin
Maxx4life is offline   Reply With Quote
Old 07-30-2005, 01:31 PM   #6
i could always do that BUT i want to make a switch so i can go back and forth between channel mixxing and independent rear steer.
Old 07-30-2005, 06:23 PM   #7
hmm... replace the 5k steering pot with a 10k pot. That might do it. Good luck finding the right size for the radio though.
FritoBandito is offline   Reply With Quote
Old 07-30-2005, 07:10 PM   #8
that might do it ORR the other way... a 2.5k pot because theres twice as much flow through the pot... but i kno there is a simple way considdering these guys did it...
He he my controler came out nice. 2 momentary push button switches mounted on a REGULAR tq radio face... so theres no ugly hole where the 3rd channel tq3 switch is...... MUST HAVE EPA POTS.....
Old 07-30-2005, 08:39 PM   #9
hey is there any way i can hook up EPA pots for the front steering on a tq3...
ALSO will a 100k trim pot work for the rear steering trim? I am getting sick and tired of using a skrew drive to center the damn thing...
