Thread: Hellllp!
Old 07-31-2005, 12:05 PM   #1
Default Hellllp!
the screw for the servo horn broke of inside of it a little bit of it is hanging out but i cant seem to get it out what should i do please help!
crawlerready is offline   Reply With Quote
Old 07-31-2005, 12:07 PM   #2
Get a new servo case. What servo is it?
mike is offline   Reply With Quote
Old 07-31-2005, 12:08 PM   #3
its a hitec 645 there is a little bit sticking out of the servo hornis there anything i can do besides gettin another servo?
Old 07-31-2005, 12:08 PM   #4
TEAM MODERATOR
EeePee's Avatar
Mike, did you even read where it broke off?
Use needle nose pliers, or any set of pliers and grab it.
EeePee is offline   Reply With Quote
Old 07-31-2005, 12:11 PM   #5
ive been trying i just opened the box and was going to change the servo horn and then i just broke off that was my first reactionand its not wanting to come out
Old 07-31-2005, 12:11 PM   #6
Oops, I geuss I skiped a couple words.
If what EeePee sais doesn't work then you may have to clamp the pinion and drill out the screw. Then re tap it .
Old 07-31-2005, 12:12 PM   #7
When did you get it? I would take it back.
Old 07-31-2005, 12:13 PM   #8
TEAM MODERATOR
EeePee's Avatar
Can you get vice grips on there? Or draw a saw across it, or Dremel a slot, and then use a flat screw driver.
Old 07-31-2005, 12:31 PM   #9
ended up having to drill it out and re-tap it did that and found another servo horn screw had to cut it down a little cause i was affraid of drilling into far but its good to go now thanks for all the help and suggestions
Old 07-31-2005, 01:32 PM   #10
this sucks i guess i messed something up when i drilled it cause now it doesnt work right =\ guess another $30 down the drain hope fully ill have another servo before wednesday so ic an have it running when i get the revo shafts
