08-23-2008, 07:30 PM | #1 |
Newbie Join Date: Aug 2008 Location: somewhere
| rc18t cells
hello all, my buddy is runnin a 7 cell 18t 1100mah pack, seems to work well. my ? is how many cells can i run? my esc says 7, but i thought maby since there small cells i could run more. there still 7.2 volt tho. any help would be helpful.
08-23-2008, 07:35 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
well a friend of mine is running a rooster crawler esc and it also says 7 cell is the max. And he's running 8 cells and has never had any problem. It would help if you wrote what kind electronics you are using. People will know a little more then.
08-23-2008, 07:46 PM | #3 |
Quarry Creeper Join Date: Mar 2008 Location: Raleigh, NC
If its a rooster esc , 7 cells is the max. Many have run 8 cells but, you run the risk of overloading the esc.
08-23-2008, 07:52 PM | #4 | |
Quarry Creeper Join Date: Apr 2007 Location: Northern PA where the rocks grow wild
A 7 cell is 8.4v.... Even though they are the small 2/3a cells, they are the same as a sub-c cell, voltage wise. Just cause its smaller doesn't mean it is putting out less. Just to be on the safe side I would not go over the max recommended cells per the ESC. I tried running a 7 cell battery on an LRP AI Runner (waterproof esc) and the max spec on that esc is 6 cell. Needless to say, it did not want to run the rig due to overvoltage of the esc. If you want more runtime, You can run 2 of them together in series(as long as they are the same rated cell and mah), and the voltage stays the same but it doubles the mah, which means longer runtime. I used to run 2 stock 18t packs (wired in series) on my crawler and it worked great. Alot of people run the smaller 2/3a cell packs on thier rigs due to size issues. | |
08-23-2008, 07:59 PM | #5 |
sorry, LRP runner plus reverse, the new style waterproof one and 35t integy pro tuned motor. I had a 4600mah on it but i swaped out my trail chassis for my stock one for some reason last night and now im goin for CG. thanks for the info, im a newbie to the site but ive been a r/c'er for bout 14 or 15 years, only been crawlin bout a year tho lol.
08-23-2008, 08:20 PM | #6 |
LOL, my packs are 6 cell, my buddy is runnin the 8.4 7 cell. i did however forget which is parallel and which is series, i also do car stereos so i should know. i thought one was +&+ and -&- at the plug, and one was a + from one pack and a - from the other pack and the other +&- together? if that makes any sence.
08-23-2008, 08:47 PM | #7 |
ps. my esc is 6 cell max,,, sorry.:-(
08-23-2008, 08:59 PM | #8 |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
sometimes you can get away with running 1 more cell depending on the quality of the esc. As said above roosters will handle 1 more. Ai's are decent esc's so I would assume a 7 is ok on the 6 but I've never owned one. Just grab a 2 cell lipo and call it good!
08-23-2008, 09:22 PM | #9 |
Quarry Creeper Join Date: Apr 2008 Location: sanford
wire in series explosive power their voltage is doubled need hd esc ,from battery plug going to lets say pack (a) the (-) from pack a to the (+) pack (b)the (-)from pack (b) out back to plug wire in parallel, longer run time easy on the electronies from battery plug (+) 's to gether and the (-) together |
08-23-2008, 09:22 PM | #10 |
well,,, im getin married in a month or so so $ it tight lol. i wana run 2 18t packs in a series but no one will tell me how. :-(
08-23-2008, 09:25 PM | #11 |
series and paralell, i thought one was +&+ and -&- at the plug, and one was a + from one pack and a - from the other pack and the other +&- together? if that makes any sence.
08-23-2008, 09:30 PM | #12 |
parallel, (+)'s together and (-)'s together series, (-) to (+) |
08-23-2008, 09:41 PM | #13 |
well, ima do that now, i'll let ya know, hope i dont fry nun
08-24-2008, 12:49 AM | #14 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
| Ive been running an 8.4 in mine (on accident in the beginning) but, have never had problems so I said screw it and have ran it no probs I shouldnt but. Its a cheap ESC and the wheelspeed I gain is worth it |
08-24-2008, 04:40 AM | #15 |
ya, my buddy's runnin the same esc and 7 cell is no problem. i wana lot with out spendin much,,, ya know, lol |
