08-26-2008, 12:39 AM | #1 |
Rock Crawler Join Date: Dec 2007 Location: GILBERT
| lipo cutoff
what should my truck do when my lipo hits that certain voltage? the power seems like its dieing not cutting off sidewinder+45t lathe+3s lipo |
08-26-2008, 01:26 AM | #2 |
Pebble Pounder Join Date: Jul 2008 Location: Australia
i don't know about a sidewinder, my goat stops the motor drive and leaves you with servo control, my FX-R will do similar i think, just make sure you have set the lipo cutoff setting in your sidewinder and all should be good. It should cut off at 3V/cell |
08-26-2008, 02:01 AM | #3 |
Quarry Creeper Join Date: May 2007 Location: Hilo
If you have the lipo cutoff set it should just feel like the batt is dead. ie it won't climb or basicly move. hehehe. If you don't have the cutoff set you should set it. The sidewinder has a auto detect setting if you use lipo's or a manual 1. If you use reg. (nimh) cells also on this truck I guess you could just watch for a drop in performance. Needs more throttle imput. Nimh with the lipo cutoff will cause problems as the batt. drains.
