Thread: placement of electronics
Old 08-04-2005, 11:34 PM   #1
I joined the Band!
Default placement of electronics
ok so i jus got my esc in today and i was readin on it and it said to place it as far away from the reciever as possible because of interference. but then i read on here some where that i should have the esc as close to the motor as possible so i wanted to do that but i also wanted to keep my esc up front for more cooling. so my question is........are any of these problems actually a real concern or will it not matter if my esc is 4 inches away instead of 8. any help will be greatly appreciated . thanx a lot.
mxracer52 is offline   Reply With Quote
Old 08-04-2005, 11:44 PM   #2
Picture shows how I have mine. I've seen folks with ESC's and RX's closer than mine. Haven't had any trouble with this set up, no glitches or anything like that. Maybe temp. wire everything where you'd like it to be and make a test run, see if it is ok. Is what I did. Hope this was of some help.
RCALLOYS is offline   Reply With Quote
Old 08-04-2005, 11:54 PM   #3
I joined the Band!
Oh deffinately some help....i guess i'll jus do wat u said n temp. put everything where i want it and see if its all good. i think i should be alright cuz it'll be about as far as u got urs spaced. thanks a lot man. ohh and hey i was jus flippin through some old mags today and i member seein ur truck in xtreme rc car magazine i think it was.............man you have one of the best rigs i eva seen.....thats some awsome work u did on that thing.
Old 08-05-2005, 07:20 AM   #4
As crawlers we have an advantage... We're never that far away from our trucks. My RC18MT is capable of well over 40mph and let me tell you, the radio setup on that truck is a pain.
That said, yeah, mount the reciever as far away from everything as you can. And that's exactly what it means, as far as you can. You don't need to mount it 8" away I don't think. My ESC is probably 4" away from the rec. and it's fine.
Also, I don't worry about wire length. As long as you use a heavy enough gauge you should be able to mount the ESC pretty far from the motor and have no problems. If you were racing and using a super high performance motor, I might feel different. But for crawling, it doesn't matter, other than just to make it look nice and neat.
-Jay
BigJay is offline   Reply With Quote
Old 08-05-2005, 10:19 AM   #5
Yep, your best bet probably is to experiment with placement. I had my RX over the motor at one time, for about 2 minutes. It didn't like that at all. Then switched 'em around and it was all good. Every once in awhile I'll get a glitch but I think it is from the SR running two servos. Least that is what I've been told. :?
