09-06-2008, 05:32 PM | #1 |
Newbie Join Date: Sep 2008 Location: Winter Haven
| Splitting a Battery
i was wondering if I could split a 3000 nimh an wondering how thanks.
09-06-2008, 05:46 PM | #2 |
Rock Crawler Join Date: Feb 2007 Location: In A Nut Shell
youll need some battery bars, wire and a soldering iron, resin core solder, flux, ow ya and some battery shrink wrap |
09-06-2008, 05:55 PM | #3 |
Rock Stacker Join Date: Aug 2008 Location: Chestnut Ridge
Yes to the above...especialy the battery shrink wrap. I made a spilt from a stick a few days ago and found out why they give it to you in a kit. Without shrink wraping each cell from a stick they will short out. I layed a bar across two batteries and then used my finger to adjust it's position for soldering and it burnt my finger good. |
09-07-2008, 01:03 PM | #4 |
Newbie Join Date: Jul 2008 Location: Outside Champaign
| splitting sub C pack...
I have done it to get the battery on the front axle. You need big soldering iron/gun, battery bars, insulating washers would be good as well, plenty of tape, solder, and glue. I had to wrap each cell as they were from a stick pack reusing the fiber washers. I had some heavy duty S&K bars I used to hold the shape well. It ended up 4 cells on top of 2 to get it on the front axle plate I fabbed up. Only catch is it's almost too much weight, afraid I may snap a C hub if I have a sudden drop/impact. I am looking at a similar configuration for my Losi MRC, just using 2/3A cells instead of sub C. The plate is fabbed and servo moved, just have to do the battery next. |
09-07-2008, 01:08 PM | #5 | |
You need the insulating washers on top of the cell to prevent shorting individual cells with the bar (easy to do when putting bars on), the heat shrink is more to stop cell shorts when they are touching (placed side by side) since the can of the battery is the NEG. | |
09-07-2008, 03:43 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
If you are planing on putting it on the axel you would be better served by getting a 2/3a pack already made as the sub Cs are to large to fit on the front axle.
09-07-2008, 04:26 PM | #7 |
09-21-2008, 08:50 PM | #8 |
Newbie Join Date: Sep 2008 Location: canada
when u turn the tires dont rub against the battery? |
09-22-2008, 05:00 AM | #9 |
| Not with them standing up. Here's another pack that I made last week and some info on building packs. CLICK HERE Last edited by LoveToROCK; 09-22-2008 at 05:02 AM. |
09-22-2008, 05:51 AM | #10 |
Rock Crawler Join Date: Apr 2007 Location: St. John's
Here's another pack made from sub c cells. I used these for a number of months with great success - they are a bit heavy but the runtime was close to 1.5 hours @ 4600 mAh. There was no rubbing at all - even at full steering lock. This is on a WK axle which is a bit wider than the AX-10. I now run a 7 cell 2/3a saddle pack that I made a few days ago and its working out fine so far. |
09-22-2008, 08:40 PM | #11 |
Rock Stacker Join Date: Aug 2008 Location: Lexington
i just pull apart my battery to make a saddle pack and i cant get it to work out it is meatling the soilder but it not sticking to the battery and i fell that im getting the battery to hot i really hope i didnt mess up my perfectly good pack that only has a couple charges on it someone shot me a pm adn give me some help
09-22-2008, 08:58 PM | #12 | |
09-22-2008, 09:02 PM | #13 |
09-23-2008, 12:21 AM | #14 |
Pebble Pounder Join Date: Oct 2007 Location: Belgium
You need to scuff the ends of the cell and a really hot soldering iron. I had the same problem with my old iron, could not get the battery bars to stick. The cell acts as a heat sink, be careful or you will overheat and destroy the cell. I got another iron, a cheap 60w and wow what a difference! The bars were no problem and infact I do most of my soldering with the new iron, I like the fact that I can sort of "tack" the joints quickly. Just be careful with small things (Deans for example), a hot iron will get the parts hot fast. |
09-23-2008, 02:27 AM | #15 |
Newbie Join Date: Jun 2008 Location: kona
