Thread: Could my servo?
Old 08-07-2005, 12:48 PM   #1
Default Could my servo?
Could my servo be causing my truck not to run properly? It was running fine until I put a new Hitec HS-945mg on it. My truck runs TQ3 tx/rx, a Hitec HFXR speed controller and peramaxx 600 motor with just one servo.
Thanks
mike is offline   Reply With Quote
Old 08-07-2005, 01:03 PM   #2
Yes, if your BEC ratiing of your speed controller is too low, then your high power servo could cause a lot of glitching in your ESC.
AdamF is offline   Reply With Quote
Old 08-07-2005, 01:07 PM   #3
how do you fix the problem? I have a similar problem where my truck won't go if the steering is in a bind and I"m trying to turn the opposite direction from the direction the tires are bound up in.
BlackSheep is offline   Reply With Quote
Old 08-07-2005, 02:28 PM   #4
I'm geussing you will have to run a reicever pack. Or you can get a speed controler with a high enouph BEC. I put the stock servo back on temporarally and that fixed the problem.
Old 08-07-2005, 02:51 PM   #5
third option in this link http://www.rccrawler.com/forum/showthread.php?t=12689
SPEED_RACER is offline   Reply With Quote
Old 08-07-2005, 04:12 PM   #6
Thread doesn't work.
Old 08-07-2005, 05:32 PM   #7
i'll try this again HOW to make a 6 volt voltage regulator!
Old 08-07-2005, 05:32 PM   #8
ok working now
