09-09-2008, 05:50 PM | #1 |
Rock Stacker Join Date: Jul 2008 Location: Las Vegas
| outrunner timing??
i got my outrunner today its the kms 2212/12 with a 16t pinon and a stock ax10 spur gear. i was wondering where the motor timing should be at. thanks |
09-09-2008, 09:09 PM | #2 |
Lowest generally works best for outrunners when crawling. The higher you set it the faster it will want to start.
09-09-2008, 11:29 PM | #3 |
ok i well set it to low and see what it does tomorrow.
09-19-2008, 12:33 PM | #4 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Does the timing change start up only? Does timing make a outrunner motor faster or have more torque? I am using a Holmes CrawlMaster 1000KV brushless outrunner in a 2.2. Gearing is 15 pinion 96 spur Mamba Max ESC 3S Lipo With the 96 tooth spur it is almost as smooth as brushed. The torque is insane. I am trying to fine tune the set up and I was just curious about what program settings I could fine tune, such as the timing. I currently have the timing programmed normal. |
09-19-2008, 01:39 PM | #5 |
RCC Addict Join Date: Jan 2005 Location: Germany north
if your timing is to low (soft) motor and esc will heat up faster and the efficiency is lower the high switching frequency is more importnt for a smooth startup thats why the quark esc starts smoother as the castle esc |
09-19-2008, 02:18 PM | #6 | |
* Low timing = faster build up of heat and lower motor efficiency (I assume the outrunner will perform poorly?) * High timing = smoother startup (does it have any other benefit other than start up?) - If I were to switch the timing setting in the Mamba Max from normal to high what will happen? - What would happen if I changed it from normal to low? I have been searching and reading through the forums the last fews days and have not found a clear answer on the subject (at least one I understand). I am trying to understand how the timing effects the outrunner and what benefits high/low timing has on a outrunner. With the current firmware on the Mamba Max, the 96/15 gearing, and 3S lipo, my crawlmaster starts fantastic and has good wheel speed. It will start even rolling backwards on a steep incline. I do not have any complaints, I would just like merely trying to understand how the timing effects the outrunner in order to fine tune it for maximum power, torque, wheel speed and efficiency. | |
