Thread: single 55t motor with 14.4v?????
Old 08-08-2005, 11:39 PM   #1
Default single 55t motor with 14.4v?????
is it possible to run a single 55t lathe motor with two 7.2v batteries. im using a stock e-maxx esc. doing searches got me nowhere. (just more confused)
MitchT-E-maxx is offline   Reply With Quote
Old 08-11-2005, 03:57 PM   #2
Spanky
I think the esc from a emaxx run's the batterys is series so i think you would have long rund times but still only 7.2 volts to the motor.. BTW the lath motors are 12 volt.
I am no 100% on this :?
asm1 is offline   Reply With Quote
Old 08-11-2005, 04:08 PM   #3
CSR
Frankee is almost right Sorry couldn't resist. ;) The EVX connects the two batteries in series, so you get 14.4 volts to the motors. Pretty sure if one motor is unplugged the other still gets 14.4V. Heavy ran 14.4V to a pair of 55T's for a long time without any problems. Like Frankie said, lathe motors are 12V, running them on 7.2V is like running a V8 at half throttle! They come to life on 14.4V!
CSR is offline   Reply With Quote
Old 08-11-2005, 04:56 PM   #4
Guys Spanky doesn't know his A$$ from a hole in the ground...
killertxt is offline   Reply With Quote
Old 08-12-2005, 04:42 PM   #5
haha, thanks alot guys im gonna go do that now.
Old 08-12-2005, 05:22 PM   #6
Get off my lawn!
microgoat's Avatar
[b] Pretty sure if one motor is unplugged the other still gets 14.4V.
the motors are wired in parallel, so running only one is fine.
microgoat is offline   Reply With Quote
Old 08-13-2005, 12:39 AM   #7
hey bad news, lathe motor started smoking when i ran 14.4v so im back to 7.2 and ill just deal with getting lwoer gearing. the nice thing about the 14.4v is that reverse actually worked. because with 7.2 reverse SUCKS
Old 08-13-2005, 02:06 AM   #8
Location: a place of settlement, activity, or residence.
I just ran my TLT yesterday with 10 cells(12v) on my new lathe motor, ran 5 packs through it and it seemed ok. Maybe you could try running 12v through the evx and see if it will work that way.
thaclodking is offline   Reply With Quote
Old 09-24-2005, 06:52 AM   #9
I have been running my lathes with an EVX for awhile now. Last Sun. the rear axle locked up on me. When I pullled the motor to see what was up I found the motor was locked up. I pulled it apart and found one of the winding wires had come loose and got jammed between the armature and one of the magnets. I wonder if it is due to the excess rpm from running 14.4 volts or if it is just a sheit happens deal. Anyone else have this kind of problem with the lathe motors?
crosstie69 is offline   Reply With Quote
Old 09-24-2005, 07:00 AM   #10
ya i would run it at 12V less strain on ESC and motor and im sure you wont notice that much decrease in speed or need it
jimbobmarley is offline   Reply With Quote
Old 09-26-2005, 02:14 PM   #11
Landy mad
wallaz's Avatar
Made myself a 12v battery pack yesterday but have noticed that I am getting arcing on the motors if I go from full throttle to no throttle by just letting go of the stick on the transmitter.
Why does this happen??
Should I remove a couple of cells for safe operation.
Running two 55T lathe motors in parallel on a Clod.
wallaz is offline   Reply With Quote
Old 09-26-2005, 05:17 PM   #12
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
you get arcing because your comm needs to be cut and trued.
running lower voltage is always safer.
as far as the motors throwing winds, the higher rpm will definatly cause more of this, but it shouldnt be an issue really. They are made for 12V after all.
JohnRobHolmes is offline   Reply With Quote
