| | #1 |
| Newbie Join Date: Aug 2008 Location: Assen
| Hello exuse me for mine bad english...(dutch) I have an Novak GOAT BL-set for mine rig. But i have an little problem, Could i switch the outer side's wires from the BL-motor?? The middle wire will not be moved, just the outer 2.. Is this possible with an sensored motor?? I hope it wil, because it is an verry tight fit in mijn Axial artr, and with this mod, it will be possible to mount it very nice, without any problems. Thanks in advance Emil |
| Sponsored Links | |
| | #2 |
| Rock Stacker Join Date: Jan 2008 Location: Reno
| If you do that the motor will run in reverse rotation. |
| | #3 |
| Do i not get timing problems wth the sensors ? I understand that with senserloss motor works, tot change 2 wires, bur this is an senserd motor, does this not create problems?, how are those sensors working??? You suppose you should change the order of the sensors? Im confused, some one says it wil work, some of them not.. |
| | #4 |
| I wanna be Dave ![]() Join Date: Apr 2004 Location: SoCal
| If you are trying to revese the motor rotation that is done through programing of the speed control. No, do not change the wire order, read the instructions. |
| | #5 |
| Emailed, Novak, No it is not possible, to change the wire orders..... Well, it is all installed nice ly, cost about 3 hours to do, but ids was worth it! An verry verry tight fit.... |
| Thread Tools | |
| Display Modes | |
