Thread: Looking to play with Lipo and the big boys..
Old 09-15-2008, 04:17 PM   #1
Prick
rambuller84's Avatar
Default Looking to play with Lipo and the big boys..
Looking to go Lipo. I have a Mamba Max and I'm looking to go 4S. I have enough room to stack two Sub C 6 cell stick packs in my battery mounting area, so size isn't much of an issue.. Any suggestions?
rambuller84 is offline   Reply With Quote
Old 09-15-2008, 10:50 PM   #2
Get a fan and a BEC if you're going to run them in series or your mamba will smoke Wtf are you putting this in? What motor you going to use? Match the battery size to your amp draw. Even if you have room, a over sized battery sucks.
chrisjlittle is offline   Reply With Quote
Old 09-15-2008, 10:54 PM   #3
Specs show 2-3S.
Robb is offline   Reply With Quote
Old 09-15-2008, 11:07 PM   #4
OCCUPY RCC!
dezfan's Avatar
The Mamba Max will handle 4S, but you will want to vent the case and add a fan to help keep it cool.
dezfan is online now   Reply With Quote
Old 09-16-2008, 11:59 AM   #5
Prick
It's just going to be one single lipo. Right now I'm running 2 6 cell NIMH in series for 14.4V through a 7T Cobalt in my scale truck. And a reciever pack runs the Hitec 805 used for steering.
I've got one ready for it.
Old 09-16-2008, 09:44 PM   #6
Maxamps, Flight power, Thunder power all make good cells. There are plenty of other good cells out there that I have no experience with though. Don't cheap out if you can help it, it sucks having to buy that stuff twice. I've only puffed one battery, which happened when a balance tap ground wire came off and then I tried to balance it I inspect my packs more carefully now before I charge them.
A good charger never hurts. Best one for the money I've found is this: http://holmeshobbies.com/product.php...3&cat=7&page=1
I almost think a lot of the fear about lipos is overblown, if you get a battery that can support your application and charge it correctly, you shouldn't have any problem. All batteries are dangerous. I've seen more nimh cells vent than lipos, and even the lead acid battery in your car can explode if not treated properly. Don't be stupid though, I'd say you'll need at the very least 50-60 amp continuous rating, charge it with the proper charger, balance it, and keep an eye on it during charging. Honestly, I'd just buy a 4500-5000 pack. It'll still be lighter than your 2 nimh packs, and you'll get ridiculous run times.
Old 09-16-2008, 10:58 PM   #7
Kamikaze's Avatar
I have one of these, its awsome to say the least. http://www.maxamps.com/Lipo-5000-148-Pack.htm
The esc will be fine but the 7t won't like it.
Kamikaze is offline   Reply With Quote
Old 09-17-2008, 04:03 PM   #8
Prick
WHOOO! Go big or go home I guess... What will the 7T not like? The amps? Only .4V more than what I'm doing now.
