Thread: Mtroniks ESC HELP!!!
Old 08-09-2005, 10:41 AM   #1
Moderator
RXcrawler's Avatar
Default Mtroniks ESC HELP!!!
I got a Mtroniks ECO 20 esc with a one touch set up. Here is my problem, installed everthing in my truck, when you move the throttle nothing happens. If you press the 1 button that is on the esc the motor will run foward but only when you have the button pressed.
Can someone tell me how to set up this ESC. Also the plug that you plug in the reciever is brown,red,orange (in that order) I assume the brown would be the same as the black wire on my other plugs, right.
RXcrawler is offline   Reply With Quote
Old 08-09-2005, 01:13 PM   #2
sim
I have an Mtroniks Sonik4 RV11 and I typed out the instructions manual for soft copy storage earlier. You can download it at
http://www.bigbigplanet.com/about/si...roniksRV11.doc
The setup instructions might be the same as yours.
sim is offline   Reply With Quote
Old 08-09-2005, 01:16 PM   #3
Moderator
RXcrawler's Avatar
Thanks maybe they are the same, I'll try later
Old 08-09-2005, 01:47 PM   #4
yes brown would be black. I had a hell of a time on my Super Duty XR at first. Can not remember what I was doing wrong. just kept starting over.
JamisonWorkshop is offline   Reply With Quote
Old 08-09-2005, 03:48 PM   #5
I had to use the online manual to set mine again, had my rv15 in my T3 before.
http://www.mtroniks.net/download.asp?ResourceID=22
boxedjuice87 is offline   Reply With Quote
