| | #1 |
| Rock Stacker Join Date: Mar 2008 Location: Canada
| I just baught an infrared temperature gauge to check my electronic components + motor. What is the safe limit for the motor (Hyperion 3025). Is it the same for all motors ? Do i have to check the Mambamax ? Does it have auto shut off thermal protection ? Maximum temp for the servos ? CC Bec temperature ? Battery ? Thanks for advice |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Aug 2007 Location: In my shop
| Motor should not exceed 200 deg. A crawler motor shouldn't even get close. Esc may be warm along with your servo. I run a hitec 5955tg and it just gets warm. for the most part in a crawler everything should just get warm. In faster buggy and truck where you are dumping alot of power for speed is where the heat comes from Travis |
| | #3 | |
| | #4 |
| I run a 3s lipo thru a CC sidewinder into a 50X1 handwound motor for a 6min comp and everythin is just luke warm while running in 100 deg summer day down here. you shouldn't have much heating issues at all |
| Thread Tools | |
| Display Modes | |
