Thread: MM programing question
Old 09-17-2008, 11:04 AM   #1
Default MM programing question
I just put a MM in a few days ago and got it all programed like I like except for one small piece. I have the throttle curve set like I like it, but I was wondering if there was a way that I was missing to set the same kind of curve for reverse. I can ease into the power in fwd and it creeps along, but as soon as I touch reverse it takes off like a bolt of lighting. I am running one of the HH 7T motors now as well. When I had my Integy 55T motor it was not that big of a deal but this new motor has a lot more wheel speed.
ElkySS is offline   Reply With Quote
Old 09-17-2008, 11:38 AM   #2
Practicing my launchs >:)
Robbob's Avatar
i dont know about changeing a curve for reverse but you can turn your reverse power down, maybe that will work for ya?
Robbob is offline   Reply With Quote
Old 09-17-2008, 11:42 AM   #3
I'm not sure about the MM, I'm sure it does. What radio are you using ? You can adjust the throttle expo. in the radio to achieve the outcome. I use a FXR with a 7T, thats what I had to do....... Hope that helps.
toytech93 is offline   Reply With Quote
Old 09-17-2008, 05:22 PM   #4
I am running a DX3.0. I have it turned down there for now. Only problem with that is that the wheel speed is there there if I ever need it. Like to save a roll over or something. I was hopping to be able to adjust the curve so that it would start off easy and if I ever needed it I could still pin the throttle in reverse and have all of the speed like you can with forward.
Old 09-17-2008, 05:48 PM   #5
Set the Brake curve the same as the throttle curve - the brake curve is the reverse curve.
Yawzer is offline   Reply With Quote
Old 09-17-2008, 06:24 PM   #6
I did not notice that. I saw brake curve and moved on. I guess I can just save the throttle curve and load it on the brake curve screen. Thank you for pullmg my head out.
