06-21-2011, 10:29 PM | #281 |
Yeah, we can do that. I plan to carry loose parts here for custom builds, and we can certainly do longer shafts too.
06-22-2011, 08:06 AM | #282 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Awesome John thanks! I have had this plan in my head for a while but have not found a motor I thought was right for it yet. Yours will definitely fit the bill. |
06-23-2011, 05:21 PM | #283 |
Pebble Pounder Join Date: May 2011 Location: Fort Bliss
Looking forward to this becoming available. I think this will be the best motor out of the ones that I've looked at for what i want to do with the Wraith. Now just to wait for this to be released.
06-25-2011, 11:06 AM | #284 |
Quarry Creeper Join Date: May 2011 Location: USA
06-26-2011, 10:33 AM | #285 |
wow, crickets chirping...
06-26-2011, 10:38 AM | #286 |
No, there are no smaller ones available.
06-26-2011, 10:40 AM | #287 |
History takes time to make... there are no other sensored outrunners made. If you can bolt up a 540 then this motor will fit but be a lil too much, which is just about right in any situation |
06-26-2011, 12:01 PM | #288 |
Ok, thanks
09-18-2011, 03:45 PM | #289 |
Newbie Join Date: Oct 2010 Location: Sweden
Any news?
09-18-2011, 05:25 PM | #290 |
Quarry Creeper Join Date: Dec 2009 Location: St. Augustine
10-14-2011, 09:58 AM | #291 |
Newbie Join Date: Oct 2011 Location: Romania
| Homemade controller problem
I built a ESC based on MC33035 IC.http://roboturk.googlecode.com/files/MC33035-D.PDF The circuit is analogical with a input potentiometer,brake pin, current sense pin,pwm optional pin,and an optional ic for loop control. It has a hall sensor for reading the position of the rotor. the circuit is working but not so well. The motor is an outrunner Emax BL4030/10 with 12 poles and 14 magnets. The problem is that it has pin 22 for selecting the 60 electrical degree or 120 electrical degree. I set it initial at 60 degree and i tried all distances combination between the sensors ,not working well because it has a FAULT led that is stopping the motor if the sensor reading is not correct. If i only leave a sensor the motor will spin but only if i spin with my hand at initial moment. I tried also with 120 degree setting.Bot not running smooth only if i turn it with my hand and only if i use one sensor. Here is an animation with order of all hall sensors . 4-POLE BRUSHLESS DC MOTOR ANIMATION In the animation the sequence is 1 0 0 1 1 0 0 1 0 0 1 1 0 0 1 1 0 1 I never achieve this logic diagram with my sensors. In my motor one sensor in piking only 2 consecutive logic 1 not tree. Can anybody tell me what is the problem because i tried all the positions. IN the animation diagram the motor is in-runner and the rotor has 4 poles. This is my motor https://picasaweb.google.com/1155468...lessController There is a link with this working bout i do not know haw. HXT modified with external hall sensors.wmv - YouTube Can anybody help me? |
10-27-2011, 02:57 PM | #292 |
We are getting back on track with this motor. The next round of prototypes is being made now, I am looking for about a 8 week turnaround before I see them. I had to redesign the sensor PCB myself which took a long ass time since I don't exactly have much time left in my days between packaging orders and winding/ building motors. Still on slate though! iulian, Do you have a debug mode where you can watch the hall sensors switch? You may consider putting an LED in series with them so you can watch the sensors switch and be sure it is never triggering more than two sensors high or low at any time. What is your hall sensor spacing, in degrees? On such a small motor there will be a very small window if sensor placement for proper commutation, and there are many combinations of sensor/ phase wiring that are wrong. First you must ensure that the hall sensors are placed and firing correctly. Then you can find the correct commutation sequence for the controller. |
10-27-2011, 03:27 PM | #293 |
10-27-2011, 06:03 PM | #294 |
Really looking forward to this motor JRH. The Tekin pro4's ain't looking so hot now that you mention this
10-27-2011, 06:14 PM | #295 | |
The Pro4 will be an awesome motor, no doubt. I won't hesitate to use them, that is for sure. It will have a higher power to weight ratio than the Revolver S, simply because an inrunner can shed heat more efficiently. The Pro4 will have a MUCH lower torque density however. | |
10-27-2011, 06:21 PM | #296 | |
10-27-2011, 08:00 PM | #297 |
I am glad to see this, my losi based scaler I built for my son is patiently awaiting one for my direct to diff conversion.
11-06-2011, 02:55 AM | #298 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
How this coming along? I love my outrunner but sensered would make it better Nik |
11-06-2011, 07:38 AM | #299 |
Still waiting on the parts so I can put them together. The biggest update is how excited I am getting!
11-06-2011, 07:51 AM | #300 |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html | ||||
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups | This thread | Refback | 10-07-2011 12:03 AM |
Sensored Outrunner motors- Revolver S - Similar Threads | ||||
are all sensored brushless motors work with any sensored esc? | jebster | Electronics | 8 | 01-02-2012 10:47 AM |
outrunner motors | toka100 | Axial SCX-10 | 1 | 07-05-2011 10:37 PM |
Sensored Motors | cyberdog | Electronics | 1 | 01-08-2010 01:33 PM |
