![]() | #21 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
Holy crap these are small!! I got some larger ones, but the motor will need modification for the largers.
![]() | #22 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
![]() | #23 |
Rock Crawler Join Date: Dec 2005 Location: Tulsa, Oklahoma
Wow that is tiny, drop one of those on carpet and you aren't ever going to find it ![]() I can't wait to hear more about this. ![]() |
![]() | #24 |
I'm gonna try. I will probably use magnet wire, and make up a tip to be so small.
![]() | #25 |
MODERATOR™ ![]() Join Date: Jul 2004 Location: Ohio
You can do it!
![]() | #26 |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
That's gonna be interesting to see, cause I know I could turn that thing into vapor in less than a second with my soldering skillz.
![]() | #27 | ||
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
| ![]() Quote:
![]() ![]() Quote:
![]() Best of luck to you JRH! If anyone can make it happen you could ![]() Now will these same motors work with a Mamba Max? Or would they require a different ESC to control them? | ||
![]() | #28 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
![]() | #29 |
Rock Stacker Join Date: May 2008 Location: oregon city
![]() | #30 |
Pebble Pounder Join Date: Jul 2008 Location: Australia
I can't wait john, sensored outrunners would be the ultimate brushless crawler motor period. I think the only reason that novak and the like haven't done it was because it would be a totally new line for them and the only market for sensored outrunners is crawlers. So for them not a big enough market to be viable. Basically the majority of brushless motors for hobby use are sensorless. In an aero application the static load on a motor is minimal so startup torque required is very little, planes and helis would see no benefit from sensors. Rc car motors is where the startup torque and precise braking is usefull and so sensored motors have been designed and marketed for onroad cars etc, these motors obviously need to be fast and have a high KV so low turn inrunner sensored motors is the norm. Novak were able to create the Goat cheaply by using the 540 inrunner sensored platform that they already had and wind a couple of high turn 540bl and call them crawler motors. They reprogrammed the esc and there you go a new product, but really a BL inrunner is a compromise for crawling but it's the only style of sensored motor avail. Good luck to you john, the market for these will be huge and will see the end of sensorless aero outrunners (and possibly lathes) used in crawlers. |
![]() | #31 | |
Newbie Join Date: Sep 2008 Location: Boston
JohnRobHolmes, I found this topic using Google. I am using Hacker Outrunners for a Robotic Project in my lab at Northeastern University in Boston. I need low speed control and will also work on sensoring the outrunners. I have a lot of resources including full CNC and Rapid Prototyping here at the school so we should share notes. I ordered a Novak Goat Crawler System and am planning to break apart the Novak motor and integrate their sensors (or equivalent ones) into the outrunner. I will know more after I receive everything and start playing. Cheers Max Quote:
![]() | #32 |
The novak sensors are designed around a 12mm rotor, 120 degres spacing I think. I have everthing ready to go here, just gotta fit the sensors in my motor now. It will be guesswork to which coil is part of which phase. I have a 50/50 chance of getting it right the first time.
![]() | #33 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
Fingers crossed for ya guys ![]() |
![]() | #34 | |
| ![]() Quote:
the hacker motor that i am going to try to integrate them into has a ~24mm diameter rotor. do you think the novak system will be incompatible due to the difference in rotor sizes? | |
![]() | #35 |
You probably wont get readings from the magnets, or they will be innacurate. Depends on how the rotor is made. Does the hacker have an iron stator ring, or is it iron free?
![]() | #36 |
![]() | #37 |
RCC Addict Join Date: Jan 2005 Location: Germany north
they have iron stator rings , slotless like Feigao and co. ![]() ![]() ![]() ![]() ![]() its not a Hacker motor ;) |
![]() | #38 |
Gonna be hard to find the proper position for the sensors on that hacker.
![]() | #39 | |
| ![]() Quote:
![]() video of the robotic joint that is under development if anyone is interested... https://myfiles.neu.edu/b.weinberg/p...to%20v1%20.mpg Last edited by maxoverclock; 09-24-2008 at 01:08 PM. | |
![]() | #40 |
Ah, outrunner. Should be easy then.
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html | ||||
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups | This thread | Refback | 10-07-2011 12:03 AM |
are all sensored brushless motors work with any sensored esc? | jebster | Electronics | 8 | 01-02-2012 10:47 AM |
outrunner motors | toka100 | Axial SCX-10 | 1 | 07-05-2011 10:37 PM |
Sensored Motors | cyberdog | Electronics | 1 | 01-08-2010 01:33 PM |
