Thread: Sensored Outrunner motors- Revolver S
Old 02-02-2015, 04:18 PM   #841
Default Re: Sensored Outrunner motors- Revolver S
If it was supposed to not have a clip. It would not have a groove. I would rather have the security of knowing it is held together by more than magnetism.
josh6575 is offline   Reply With Quote
Old 02-02-2015, 04:25 PM   #842
I can pull mine apart as well, was weirded out at first too. It's an excellent motor.
Meatwad is offline   Reply With Quote
Old 02-02-2015, 05:34 PM   #843
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
No circlip because they don't need it and it makes cleaning and repair easy. The option to install one is there, but we don't on purpose.
JohnRobHolmes is offline   Reply With Quote
Old 02-02-2015, 05:41 PM   #844
ah ok thanks john i was slightly confused on the matter lol fantastic build on the motor
AtlRccrawler is offline   Reply With Quote
Old 02-02-2015, 06:03 PM   #845
That is originally what I thought Josh
But there is no need for any at all.
holycaveman is offline   Reply With Quote
Old 02-02-2015, 06:34 PM   #846
I'll give it a try.
Old 02-02-2015, 06:41 PM   #847
MODERATOR™
EeePee's Avatar
I got one back in May 2012: EP's B.A. Bronco
Been fine.
EeePee is offline   Reply With Quote
Old 02-02-2015, 07:05 PM   #848
Corey I read you were going to put it in the Losi. Did it have enough guts for it?
Old 02-02-2015, 07:14 PM   #849
MODERATOR™
EeePee's Avatar
It certainly did. I just didn't like all the wires and stuff associated with sensored and the CC BEC and the layout of the Losi. Call me particular about that stuff, though it's easier to be when you got a few choices on hand. Before I went to the BA Bronco thread I was looking in the Losi thread but got tired of flipping through all those pages.
Old 02-02-2015, 07:20 PM   #850
Wiring is easy for me. I am not picky. Just wad them up and put zip ties around them.
Old 02-02-2015, 08:32 PM   #851
Originally Posted by hotwheels000 View Post
Hey John Robert, just ordered the s540s stubby for my C2 rig with 4.75 tires. She weighs in at 5lbs....
Can you confirm that the choice was wise or should I order another motor ?
Curious to hear what you think of these fancy little motors Devlin
sam63 is offline   Reply With Quote
Old 02-02-2015, 09:06 PM   #852
5lbs is nothing for these little motors I'm around 8lbs with 80-90f temps after hard running. Plenty of torque to flick the 1.9 growlers around.
Old 02-03-2015, 10:41 AM   #853
I read back through the thread and it seems like the MMP is the goto ESC for this motor any reason to go with the monster or monster 2¿
dezrik is offline   Reply With Quote
Old 02-04-2015, 01:45 AM   #854
Originally Posted by dezrik View Post
... any reason to go with the monster or monster 2¿
Only if you really must.
Otherwise it just adds cost, weight and size. And it can't handle sensors.
Olle P is offline   Reply With Quote
Old 02-04-2015, 01:50 AM   #855
the mamba monsters don't have a sensor port...only the MMP does.
fr8cture is offline   Reply With Quote
Old 02-04-2015, 04:24 AM   #856
I missed that one. Thought all Mamba-series ESCs are as versatile as the MMP...
Old 02-04-2015, 08:55 AM   #857
Dang, already sold out of the standard 540 size. When are more of those and more of the 550 models expected JRH?
Wes
WesTX is offline   Reply With Quote
Old 02-04-2015, 09:09 AM   #858
A little tip for those new to these motors. They have more torque than you know. I have been competing a year with one in my class 3. Geared 25/80. They pull tall gearing really well and still creep slow. 3 or 4s is fine.
Anyways just a tip. Don't be afraid to gear it tall
Old 02-04-2015, 09:13 AM   #859
^ Great advice. I have my first two on the way. 1 will be going into a D110 that will probably weigh well over 10 lbs when all is said and done. The other probably will go into a multi-axle this spring. As you suggest, I'll start tall on both and go from there.
new2rocks is offline   Reply With Quote
Old 02-04-2015, 01:55 PM   #860
Will the gen2 in 3s still run this 540? Out of stock right now. Any idea when be back in? I like the idea of 32p 18/58. Thoughts?
panama is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html
Posted By For Type Date
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups This thread Refback 10-07-2011 01:03 AM
Sensored Outrunner motors- Revolver S - Similar Threads
are all sensored brushless motors work with any sensored esc? jebster Electronics 8 01-02-2012 11:47 AM
outrunner motors toka100 Axial SCX-10 1 07-05-2011 11:37 PM
Sensored Motors cyberdog Electronics 1 01-08-2010 02:33 PM
