![]() | #961 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
![]() | #962 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
I'm excited to get my rig together to see what all the fuss is.
![]() | #963 |
I think a lot of people have went with these pro4's and 412's sacraficing that low speed control for power and speed. The revolver gives you that low speed control needed for precise crawling. And it still has the torque needed for launching your rig through the air. Kind of like a good brushed motor on steroids. It's not the perfect motor for everything. Speed freaks and bashers won't benifit much if at all with it. I like it for competition. |
![]() | #964 |
I wanna be Dave ![]() Join Date: Jul 2009 Location: Rancho Relaxo. California. USA. Earth.
^^^ spot on. Also it seems the brushless freewheeling problem is not as bad with the revolver s, as opposed to the inrunners.
![]() | #965 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
^^^^ That's the first thing I noticed also. Easier start up and down hill descent supurb. Compared to my roc 2600.
![]() | #966 | |
| ![]() Quote:
I know guys selling the ROC's and Pro4's for Trailmaster's.. I've replaced a couple of mine myself. ![]() | |
![]() | #967 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
| ![]() I'm loving my Trailmaster, and you might see some of them up for sale when the Revolver is back in stock!
![]() | #968 |
Rock Stacker Join Date: Mar 2014 Location: North Bay
Is the trailmaster pro brushless a good motor for my yeti? I bought a rx8 gen2 and am currently running a castle 1410 3800kv. I have a holmes BR-XL and crawlmaster in my wraith and i am very happy with it.
![]() | #969 |
Iv had to change back to a roc. The stubby cant handle the 6lb rig. Tried gearing 10/60 3s And still to hot. Waiting on the 540s. I understand it can handle 10lb rigs. Rs gen2 CcBec/ 7955 3s 10/60 32p |
![]() | #970 |
RCC Addict Join Date: Jun 2006 Location: Maryland
![]() | #971 |
^^^^^^^^^^ keeping fingers crossed tooo
![]() | #972 |
Pebble Pounder ![]() Join Date: Jun 2014 Location: White Plains
| ![]() I'm having issues with the stubby on an RX8 Gen2, can you send me your settings?
![]() | #973 |
My first run with it the settings were 2s profile 1 Drag 80 and on dual mode. No heat but no speed. Then started tuning esc Trying to run 3s: Sensored only. Custom voltage 3.3 Dead band 10 Drag 80 C1 throttle no punch Boost timing 0*(min) No current limit. Last edited by panama; 03-17-2015 at 02:38 PM. Reason: Changes |
![]() | #974 |
Rock Crawler Join Date: Feb 2011 Location: Williston
would love to get the full sized version of this!
![]() | #975 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
I would suggest folks needing a motor right now or soon to go ahead and buy something else, it is going to be a while. We are having some forwards / reverse precision issues with certain motors or ESCs or programming. Where the driver can't rap the motor back and forth without it loosing sync at some point. I think one point we should address before going further is the particular wind pattern used, it has a floating zero reference that changes with rotation direction. I need to test some other patterns and see if the factory can improve their alignment jig. Because of this, the current style of 35mm OD Revolver is going to take a while to bring back into a regular inventory swing. I've been working on a 32mm OD 2nd Gen and we should be able to get it into rotation sooner. It has better precision of timing alignment and the proper wind pattern already solved. I wish it was a little easier to get these 100% correct the first time around! But I suppose if it was easy then everybody would have done it by now. The hardest part is getting another factory to replicate what we want, and not having enough labor to bring the full assembly in house. Goal for 2015- if I haven't been able to get steady inventory of a sensored outrunner from a "regular" factory I will make a dedicated assembly line in our shop for them. Prices will have to go up, but a $100 or $150 price is still within the lower range of quality name brand motors I suppose. |
![]() | #976 |
Is this just isolated to just the stubby or both?
![]() | #977 |
I must have got lucky. Both my standard size and stubby work perfect.
![]() | #978 |
Both sizes can present the same issue. The evident cause is sensor alignment, the root issue is not the sensor location but the back EMF of the motors. Most motors work just fine, but there are enough to make me find the area for improvement.
![]() | #979 |
Rock Stacker Join Date: Dec 2013 Location: San Jose
| ![]() Well, good thing I just picked up your Trailmaster BL to hold me over. Until then, I do hope you get things figured out soon. Keep up the great work John!
![]() | #980 | |
| ![]() Quote:
Thanks! | |
![]() LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html | ||||
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups | This thread | Refback | 10-07-2011 01:03 AM |
are all sensored brushless motors work with any sensored esc? | jebster | Electronics | 8 | 01-02-2012 11:47 AM |
outrunner motors | toka100 | Axial SCX-10 | 1 | 07-05-2011 11:37 PM |
Sensored Motors | cyberdog | Electronics | 1 | 01-08-2010 02:33 PM |
