Thread: Sensored Outrunner motors- Revolver S
Old 02-14-2010, 06:56 AM   #141
Excitment abounding John, can't wait to see them.
JC
skid plate is offline   Reply With Quote
Old 02-21-2010, 02:59 AM   #142
Uli
I´m really anxious to see how your sensored outrunner turns out to be. are they going to be in the area of your other outrunners, size- and powerwise? Is scorpion going to produce them?
Greetings, Uli
Uli is offline   Reply With Quote
Old 02-21-2010, 09:01 AM   #143
Greetings, Uli
Just go back 1 page, at the bottom will answer your ??????'s
JC
Old 02-23-2010, 01:05 AM   #144
Originally Posted by JohnRobHolmes View Post
There is always tradeoffs with construction on a motor, so I have a few different designs in the pipeline. The most likely first comer will be a 540 size outrunner, and 540 or 550 inrunner. Then a 400- 499 size outrunner of 28mm OD (1.1")
I hope the new outrunners will only have the diameter of a 540, as the crawlmaster, but they will be shorter than 60 mm. I liked the dimension and weight of the old crawlmaster too much so I'm ready to buy anything which looks like it.
JRH, are you conscious we need a cheap and bullet proof sensored esc too ?
Bye
Filippo
setecastronomy is offline   Reply With Quote
Old 02-23-2010, 10:27 AM   #145
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I am very conscious of the need for a sensored controller too.
Scorpion is one factory I am considering. Each factory has tooling and capabilities that are good for certain motors.
The first plan is an outrunner that is slightly smaller in diameter than the crawlmaster, but the normal length of a 540 motor. I see that the short motors would be wanted as well, so I will likely release a stubby version too.
JohnRobHolmes is offline   Reply With Quote
Old 02-23-2010, 06:18 PM   #146
If you could make a stubby outrunner for around $50 and a sensored ESC for $100 or just over that would be wicked. And if you could match the speed, torque and smoothness of a 7t puller I would buy at least 2 and maybe up to 4 of everything Oh and please make sure that the drag brake is better than the goats too.
Kieren
Aussie Nerd is offline   Reply With Quote
Old 02-24-2010, 12:33 AM   #147
wow...ive been into brushless outrunners for planes, helis, and boats.... and have used sensored systems for my fast cars...... but now you have just go and mix it all up...lol j/k good work keep it up
the smooth motor start up will be great for those "holy crap!!" moments, the brakes will be smoooooth and we will really see a difference with our exponential and drag brakes.
motor cogging results in loss of runtime and excessive heat.
its gonna be tough to figure out sensor position and esc sensor compatibility due to the amount of poles inrunners have compared to outrunners. rite??? would a regular censored esc push a modded sensored outrunner due to the increase in poles?? i know that outrunners are really rough running when put too far outta timing. can blow an esc fast.
i guess all you can do is try try try....rite?
ive been through and experimented with alot of esc's.. may not be able to tell you what to do....but i can tell you what not to do!!! lol
sudden_scaler is offline   Reply With Quote
Old 02-24-2010, 10:19 AM   #148
MSH
Hi John,
did you talk to Lutach about this?
Your and his mind combined, imagine the power!!!
MSH is offline   Reply With Quote
Old 03-10-2010, 07:02 PM   #149
Moderator
whoodie's Avatar
Any news John? I'm about to throw all of my brushed motors away, cutting comms was so 2009
whoodie is offline   Reply With Quote
Old 04-12-2010, 04:48 AM   #150
How are these going? How did the last proto turn out?
Kieren
Old 04-18-2010, 05:08 AM   #151
Kieren
X2 I keen to hear an progress
Hulksta is offline   Reply With Quote
Old 04-18-2010, 10:40 AM   #152
Nothing new yet, but I have another proto coming to me and updated sensor boards in development.
Old 04-28-2010, 11:24 AM   #153
Update?
John82601 is offline   Reply With Quote
Old 05-09-2010, 08:22 AM   #154
Update coming this week! That is all
Old 05-09-2010, 02:49 PM   #155
Lextronix is offline   Reply With Quote
Old 05-09-2010, 04:29 PM   #156
Really?, I can't wait!!!!
meao is offline   Reply With Quote
Old 05-09-2010, 06:37 PM   #157
Old 05-09-2010, 09:09 PM   #158
Official Cook of the ECC
Scattman's Avatar
Whatcha sending Hurley?
Scattman is offline   Reply With Quote
Old 05-13-2010, 01:32 PM   #159
Dissapointment :( The motor was no different than I could make myself (think hot glue and loose sensors), and one of the sensors wasn't even soldered in properly.
Now you guys see why this thread is so damn old? Multiple prototypes, and still no factory that can get it right.
Old 05-13-2010, 02:27 PM   #160
Sorry to hear.
Add that as a goal in your list of Life Long Accomplishments.
44newman is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/136315-sensored-outrunner-motors-revolver-s.html
Posted By For Type Date
Outrunner for rock crawler - Kv and low-speed smoothness, is my theory sound? - RC Groups This thread Refback 10-07-2011 12:03 AM
Sensored Outrunner motors- Revolver S - Similar Threads
are all sensored brushless motors work with any sensored esc? jebster Electronics 8 01-02-2012 10:47 AM
outrunner motors toka100 Axial SCX-10 1 07-05-2011 10:37 PM
Sensored Motors cyberdog Electronics 1 01-08-2010 01:33 PM
