09-19-2008, 07:19 PM | #1 |
Newbie Join Date: Aug 2008 Location: Lower Mainland, B.C.
| Weird servo?? problem
Short story: when I turn the wheel on my transmitter, the wheels turn side to side as per normal, but the wheels turn backward as well, as if I had also pressed forward on the transmitter trigger. I think I've narrowed it down to the servo. It's a 645, which I bought last week because my old Futaba S148 was really weak. When I plug in the Futaba servo, the problem goes away. This problem only started yesterday after I got home from crawling. I've swapped everything except for the ESC; I don't have a spare. I suppose that it's possible that the servo did get wet inside. Should I take it apart to check? Another possibility is that my ESC(an ancient Futaba) can't handle a more powerful servo. But then why would it only start having problems now, instead of when I used the Hitec for the first time. any suggestions would be appreciated |
09-19-2008, 11:15 PM | #2 |
Rock Crawler Join Date: May 2007 Location: lacey
What kind of radio are you using? If it is a digital programmable radio maybe you accidentally added a mix???
09-19-2008, 11:48 PM | #3 |
